Hello all,
Running the trial of 5.0.7 and my mk2 w/ VDJ Timecodes. I am having trouble with the pitch setup.
The problem that I am having is that when I config the TC to relative or smart and pitch diabled or enabled and keylock on or off I cant get the BPMs to stay at the default bpm which it was scanned at. In other words if the song is at 100bpm and the record slows down the bpm slows down with it 95bpms etc.
How do I config it to stay at the default bpm without the bpm bounceing around?
Thanks in advance.
Thanks in advance.
geposted Thu 29 May 08 @ 2:18 pm
Try altering the Pitch sensitivity in the TC config, to round 2000 and see if that's the bpm from bouncing around.
geposted Thu 29 May 08 @ 2:24 pm
It seems like that makes it worse. Now if I run at 100 with keylock off it seems to be better but not accurate. Other setting i need to have set??
geposted Thu 29 May 08 @ 10:45 pm
Keep Key lock off, CPU has to work harder with it on, and uncheck Clear sound
geposted Thu 29 May 08 @ 11:00 pm
Ok that cleared thing up a bit...
Is it normal with clear sound disabled to hear slight crackles/pops when timcodes are moving slowly? In case you need to know have a maya44 SC, with shure cartages.
geposted Thu 29 May 08 @ 11:54 pm
