CUE RMX by Cioce
Here a good mix of the original Numark Cue internal mixer & video skins but now in widescreen size and with Audio & Video central panel.
http://www.virtualdj.com/addons/skins.html?display=all&order=smart&search=cioce
New version 1.8
- Single or Double top waves option
- New smart_cue and smart_play buttons
- TimeCode buttons automatic appear only if TimeCode are in use
Available resolutions:
- 1280x768 Only PC
- 1280x800 PC & MAC
- 1280x1024 PC & MAC
- 1440x900 PC & MAC
Attention: It require Virtual DJ or Numark Cue/VV 5.2
New version 1.8
- 1280x768 Only PC
- 1280x800 PC & MAC
- 1440x900 PC & MAC
geposted Mon 02 Jun 08 @ 12:25 pm
Look great Cioce, thanks for the update:)
geposted Mon 02 Jun 08 @ 12:42 pm
Thanks Cioce, love it mate,
Like the Bypass feature on the timecode button, Full marks going out to you mate.
Thanks guys, I will see if Pasco123 can resize to 1440x900.
I know some fonts are too big in MAC version, if some volunteers want to adjust for MAC I will be very happy ;)
geposted Mon 02 Jun 08 @ 2:20 pm
Users can use the new Skin resizer that JeremK has created, it works quite well.
geposted Mon 02 Jun 08 @ 2:32 pm
This is awesome! Thanks :)
geposted Wed 04 Jun 08 @ 4:40 pm
My BPM tap does not seem to work on my MAC, any ideas?
geposted Thu 05 Jun 08 @ 11:24 pm
Your MAC version is 5.0.8 and the Beat Tap function is only inclueded into latest VDJ 5.1 but for the moment is not available for Mac.
geposted Fri 06 Jun 08 @ 2:33 am
Cioce good skin I did a few modifications regards http://www.virtualdj.com/blog/dj%20fandos/
geposted Sat 28 Jun 08 @ 2:31 pm
I like this skin alot!!! I have been looking for something good that I like for 1280x800. Thanks.....
geposted Sat 05 Jul 08 @ 5:28 pm
Thanks jimspinnin, also 1280x1024 will coming soon thanks to JeremK tool ;)
geposted Sun 06 Jul 08 @ 5:12 am
Nice Skin cioce. I like it :-). But can you make a Download for Mac Users?
Best Regards Armin :-)
geposted Mon 07 Jul 08 @ 1:31 am
1280x800 is available for PC & MAC here http://www.virtualdj.com/addons/skins.html?display=all&order=smart&search=cioce
Do you want the 1440x900?
PS. I know some fonts of my skin are too big on MAC and I don't have a MAC to fix it :(
geposted Mon 07 Jul 08 @ 1:53 am
Yes Please. I have Mac Book Pro 15". The normaly Size is 1440x900.
Thank you so much :-)
geposted Mon 07 Jul 08 @ 4:17 am
CUE RMX by cioce (1280x1024) V1.6 Pc & Mac
CUE RMX by cioce (1440x900) V1.6 now also for Mac
Download -> http://www.virtualdj.com/addons/skins.html?display=all&order=smart&search=cioce
Many thanks to JeremK for resize and Moramax for the fast upload ;)
geposted Tue 08 Jul 08 @ 2:52 pm
Wow, Thank you so much. :-))))))))))))))))
geposted Wed 09 Jul 08 @ 4:11 am
Hi Cioce,
Since I found Cue Skin, I have been using it, but now I cant benefit of the new features of VDJ 5.1 because my notebook is quite old, it work with 1024 x 768. I love your skin and i would appreciate very much if you could resize for me your wonderful Skin.
also, Im experimenting with Harmonic mixing technics and would be very usefull if you can incorporate a "Key" visualization window with a "Key" Knob to modify it.
Thanks in advance, and sorry to bother you
geposted Sun 13 Jul 08 @ 10:34 am
cioce wrote :
- New multibuttons fot Hot/Set 6 CUEs - Time Code Active/Bypass - Deck Skip/Seek/Key/Cbg/Clone/Clone no pitch/Reverse
- New function to switch from "Artist - Title" to song "Full time / Key Original & (Mod) / Camelot / Comment" just click on the text song
For the moment is present Key + and - buttons and Key Original & (Mod) and Camelot are already indicated too.
For the resize is possible with JeremK tool, you can buy it the FULL version and resize 1280x1024 to 1024x768 ;)
geposted Sun 13 Jul 08 @ 10:55 am
why are these links down?
geposted Tue 23 Sep 08 @ 1:50 pm
Search is the way ;)
geposted Tue 23 Sep 08 @ 1:52 pm
