I know that it has been brought to the attention of the developers... and hopefully GumShoe won't come in here with his .02 this time. Just wondering if the karaoke zip file problem is in fact being looked at.
Reason I am asking is I just purchased up a bunch of 9000 series Sound Choice cds and encoded them. I can't use the newer compression ratio without VDJ coming up with errors. I am seeing a decent amount of size difference between the two as well as less errors (especially when you think about 100k+ songs).
This has been an issue since the beginning and has been been brought to light as of December 2007. As I have said previously, I am more than happy to help with this. Not trying to nag, but please keep us updated as to the status of this.
Thanks much
Rob - Chicago IL USA
Thanks much
geposted Thu 05 Jun 08 @ 10:58 pm
It's on the TODO list like a lot of other things ;-)
It's impossible to develop everything at the same time even with the best will.
geposted Fri 06 Jun 08 @ 12:44 am
Thanks cel :)
geposted Fri 06 Jun 08 @ 5:48 am
