What is the CPU bar at the top of the screen when your in video mode?
geposted Sat 07 Jun 08 @ 2:03 pm
It's there to show you how much CPU usege you are using, because mixing video is heavy on you CPU.
geposted Sat 07 Jun 08 @ 2:07 pm
sometimes when im just mixing music it will go all the way up, and i'll hear glitches.
geposted Sat 07 Jun 08 @ 2:15 pm
You might want to go into your Task Manager and turn off some processes and see if that helps. Also if your connected to the net using a wireless card turn that off. It might help...;)
geposted Sat 07 Jun 08 @ 2:22 pm
You can also change your performance settings in VDJ for faster instead of higher quality under config>performance tab.
geposted Sun 08 Jun 08 @ 12:23 am
