is the Xone d3 compatible with VDJ
geposted Wed 11 Jun 08 @ 4:47 pm
It works 100% on Virtual DJ ;)
You can buy a PRO version http://www.virtualdj.com/buy and after this you can download the mapper from here http://www.virtualdj.com/addons/view.html?type=tool
geposted Thu 12 Jun 08 @ 2:16 am
vdj and xone:3d combo is awesome. i made the midi map and i have to say the mixer has made me quite lazy :-D. spinning at home, i dont need to touch anything on the pc because i can control everything i need from the xone surface. however, when i play out, it then becomes more work which is not bad at all but you really get used to the xone....
geposted Thu 12 Jun 08 @ 10:34 pm
That thing is like the mack daddy.
I guess the price pushes it out of alot of budgets.
geposted Fri 13 Jun 08 @ 10:44 am
yes, its not cheap. however theres a philosophy that i live by. if you're serious about something, never buy cheap. because the lifetime of value it has to you is short. you'll buy something on budget and be pissed off with it after a year. do that 3 times and you've spent more over 3-5 years than if you would have bought the expensive one to start.
geposted Sat 14 Jun 08 @ 10:32 pm
There is a Xone 4D now!
geposted Sun 15 Jun 08 @ 12:08 pm
There you go people
I have to say it's VERY NICE In the UK it retails at £1500, comes with Ableton LE or traktor DJ3.
It's well out of my price range, but it look fantastic when the lights are out.
geposted Sun 15 Jun 08 @ 12:26 pm
