Forum: Old versions
Topic: EQ bug
I just changed the eq tonight in deck 2 ( the bass) and the song skipped i had a 16beat loop on deck 1
and one effect on (North Pole)
Andre
geposted Wed 05 Jan 05 @ 1:01 am
The issue is known. It seems to appear when your computer has low ressources and only when you use buttons on a skin (not with key shortcuts)
I have this issue many times, since 1.x versions.
Using the EQfader, but with keyboard shortcuts.
When mixing 2 tracks and move lets say the bassfader, there is a skip/mute sometimes.
Note1: This happens to both tracks, strange but, the 2 tracks remain in sync (if they were in sync before)
Note2: This happens ONLY the first time.
Then i can move the sliders (using keyboard shortcuts) without probs.
(looks like it is a buffer ploblem to me)
Same problem here.
But i have this issue ONLY in my desktop (allot of files-internet downloadings-etc.etc.).
And i have not this prob. in my laptop (only for VDJ)
i have the same problem..seems to be in the begining and then works fine... but not predictable...
maybe it has something to do with the mouse driver?... since i only have problem when using mouse..
No, it is with keyboard too..
This happened again tonight and this time i was changing the mid setting with the dj console and got the same results...cpu and commit charge low so its not ressources!
No loop this time just eq only
Andre
Its a sound skip, it looks like a buffering problem to me, like vdj is not ready when the user move
the eq sliders.
I also have the same problem . You have to watch out and not change the hi EQ settings while a song is playing on the other deck.
Ok seems to me if i change it with the console slowly its doesnt do anything to the song that is playing,if you inna rush well ther is a 50/50 chance it skips.
I had no problems last night and i used it a lot?????
Andre
Well, I had that problem too. I think that VDJ did not load to RAM all efects (including EQ), so, he loads EQs when you start using them first time in night. So there is 2 solutions:
1. When you turn on VDJ, load 2 songs, left & right, and mix them for a few minutes, and then start using EQs and you will not have that problem again.
2. Buy an external mixer. It is a GREAT sollutions + not expensive :) You have fader, EQ's, Kills, all in front of your hands...
When you start VDJ, the sofware loads the plugins currently let in slots as you have just done a drag'n'drop.
For plugins developers VDJ initializes the function Onload() when VDJ starts
I work everyday with VDJ and now I'm not using FXs because there is too much problems .
I think : if I like the Fx I need to buy a new Mixer (djm 600 for example)
I have VDJ with turntables (TCV) and the program rocks . I can do loops and samples : It's enought for me ....I have used fx and fader (bass , high and mid)but with some problems -
the big limitation is the bad bpm detection , I think this is the REAL PROBLEM HERE , because with bad bpm I can't do loops , and samples are out of sync - I've tried any music or techno and always the same : wrong bpm (some songs) - the way here must to be READ TAGS and always I can analize my songs with another software -
