what does this do? its under options.
geposted Sun 15 Jun 08 @ 4:23 pm
You can choose to allow bpm lower than 80bpm or not :)
Its for preventing or minimizing the possibility of half/double detected bpm's, and therefore can be used to disallow bpm's lower than 80bpm
geposted Sun 15 Jun 08 @ 7:44 pm
Norway...If we select enabled...or do NOT scan bpm less than 80 will it leave a blank in the BPM field, or what? That was a problem w/ many files in last version it halved or doubled the bpm incorrectly,,, NOW with 5.1 will it overwrite that bad data on files that are truely less than 80 bpm?
geposted Sun 15 Jun 08 @ 9:12 pm
5.1 will find less half/doubles than earlier versions ;)
if you choose not to allow bpm lower than 80bpm, VDJ will not leave it blank. It will either leave the bpm already for the file, or try a higher bpm. So if the song is truely lower than 80bpm, and you have turned on not allow this, it would most likely give you the double.
geposted Mon 16 Jun 08 @ 1:43 am
