Forum: VirtualDJ Skins
Topic: timecode on/off & audio through command
SZ-BHome userMember since 2004
i´m creating my own skin and i was wondering if there are "actions" (xml-file) for turning the timecode on/off (so you can use a desk with or without timecoded records) and for passing the audio signal through ( on active desk ) . right now i have shortcuts for that , but i want to have buttons for that in my skin .
geposted Thu 06 Jan 05 @ 1:36 pm
djcelPRO InfinityModeratorMember since 2004
For the LEFT DECK, here is an example:
button action="timecode_active" chan="1">
size width="19" height="18"/>
pos x="127" y="199"/>
selected x="106" y="781"/>
down x="106" y="781"/>
over x="131" y="781"/>
/button>
Sorry for the first symbol (inferior), i can't write it on the forum
geposted Fri 07 Jan 05 @ 3:07 am
I talked about this symbol <
geposted Fri 07 Jan 05 @ 4:47 am
thank you so much!!!
is there an "action" (command) for passing the audio from the line inputs through to the line outputs ??
geposted Fri 07 Jan 05 @ 7:40 am
i found the other one myself :
action : timecode_bypass = audio through on/off
action : timecode_active = use tcv on/off ( thanks!! )
geposted Fri 07 Jan 05 @ 7:49 am
cetanuPRO InfinityMember since 2004
I,
Does it exist cheats in xml code to set timecode button 'off' by default?(like value="??")
Thanks,
Cetanu.
geposted Tue 17 May 05 @ 9:20 pm
FruitPRO InfinityMember since 2003
LOL Cetanu... Don't think so, but.... it would be great.
FRUiT94
geposted Wed 18 May 05 @ 12:02 am
