I noticed that VDJ has different or mismatch Bit Rate readout with some other softwares.
I tried to compare it from windows file properties but it seems they don't have a common result unless I rip it with WMP.
Same as true also with MP3's that I downloaded both LEGALLY and ILLEGALLY, VDJ really gave different Bit Rate Result, most commonly lower to what's in the property.
Why? or which is telling the truth?
geposted Tue 24 Jun 08 @ 6:55 am
If you have an MP3 that is encoded with a variable bit rate (VBR), you might get mismatched readings simply because the bitrate changes throughout the file.
geposted Tue 24 Jun 08 @ 8:06 pm
Thanx...djderricke...i'm worried if i will re-encoding my files to CBR it might change the quality of it.
Any advise, please?
Any advise, please?
geposted Wed 25 Jun 08 @ 2:50 am
I wouldn't re-encode unless you have to original source. VBR should be fine.
geposted Wed 25 Jun 08 @ 11:09 pm
Thanx again pal...
One more thing, i still have lots of CDs to be ripped, which do you advise, VBR or CBR?
Thanx
Thanx
geposted Thu 26 Jun 08 @ 9:26 am
CBR. The file will be bigger but your sound quality will be consistent.
geposted Thu 26 Jun 08 @ 9:13 pm
