Was wondering if Traktor scratch Time coded vinyls would work with Virtual dj
geposted Tue 24 Jun 08 @ 11:22 pm
Yes if you bought the full product or upgraded your cue at a discount (uk and us customers only)
Kind Regards
Simon Bangs
Numark Computer DJ Product Specialist
Numark Alesis Europe Ltd
Kind Regards
Simon Bangs
geposted Wed 25 Jun 08 @ 3:30 am
Traktor scratch Timecoded vinyls are not supported yet in VirtualDJ v5.1
geposted Wed 25 Jun 08 @ 1:24 pm
The signal wave form in the set up is showing a nice smooth wave... as it should but the quality % reads 0
When i play a track it goes at lighting speed and sounds like alvin and the chipmunks
I tried the auto config and configuring it my self so i get the nice smooth wave but it still reads as 0%
Im using the Audio 8 dj box that is provided with the traktor package
geposted Wed 25 Jun 08 @ 3:48 pm
And yes it is a clean copy of VDJ
Just havent registered it yet cuz i cant seem to find my serial key.
room got completely re done so its missplaced somewhere.
anyone know how to fix this solution?
geposted Wed 25 Jun 08 @ 5:57 pm
Traktor vinyls arent supported yet :)
geposted Wed 25 Jun 08 @ 6:07 pm
does anyone know when they will be supported? next version possibly?
geposted Wed 25 Jun 08 @ 6:21 pm
