Numark X1USB
Anybody that uses here this for VDJ?
Is it compatible / useful with VDJ/CUE?
geposted Fri 27 Jun 08 @ 11:19 am
I use a Numark DXM01USB mixer with VDJ and CUE it works fine with both. It is not, however midi compatible. So the fader on the skin stays in the center, which is fine with me.
geposted Fri 27 Jun 08 @ 11:23 am
That would be fine also for me if that's of the same case with this newbie from Numark.
Thanks for the input...
geposted Fri 27 Jun 08 @ 11:39 am
Please note that the mixer support is only included in the DMC2 version of cue le.
If you need full mixer support for other controlers or want the full products features you would need to upgrade to the full product.
US and UK customers can do this by calling their support line.
Kind Regards
Simon Bangs
Numark Computer DJ Product Specialist
Numark Alesis Europe Ltd
Skype : NumarkSi
Kind Regards
Simon Bangs
Skype : NumarkSi
geposted Fri 27 Jun 08 @ 3:51 pm
Kind Regards
Simon Bangs
Skype : NumarkSi
Kind Regards
Simon Bangs
Skype : NumarkSi
Thanks Simon...
But now it confuses me...
What i really need is a kind of mixer that has an internal soundcard so i can use it for my cue and some other applications. Is there something like that?
geposted Sat 28 Jun 08 @ 3:24 am
Alright if you want to use a mixer (2 output channels) with the software you need either a DMC2 (authorizes this) or the full cue (available at discount).
You can use a usb mixer or a 4.1 sound card such as the DJ.io and an standard mixer.
Kind Regards
Simon Bangs
Skype : NumarkSi
Kind Regards
Simon Bangs
Skype : NumarkSi
geposted Sat 28 Jun 08 @ 5:03 am
This is very nice.
Let me check with Numark how much the discount will be and hold on 1st w/ my order of VV.
Sorry, i guess you can answer my query above, based on you signature. Thanks...
This is very nice.
geposted Sat 28 Jun 08 @ 5:14 am
Discount is available for DMC2 or Total Control users in US or UK :
US Customers : 401.658.3131
UK Customers : 01252 353 850 / Direct from me.
Kind Regards
Simon Bangs
Skype : NumarkSi
Kind Regards
Simon Bangs
Skype : NumarkSi
geposted Sat 28 Jun 08 @ 5:16 am
