Is a database utility tool in the works to fix corrupt databases? I'm a PCDJ user and have had to clean up dups twice now. I also had to re-tag my videos (not fun) recently.
I saw there was a utility for an older version but it said not to use on 5.0+.
Thanks.
Thanks.
geposted Sat 28 Jun 08 @ 4:33 pm
The functionality is included in the latest demo of 5.07 config > browser run , check , clean and fix tools.
geposted Sat 28 Jun 08 @ 5:50 pm
Again..I'm using PCDJ VJ...not VDJ.
geposted Sun 29 Jun 08 @ 3:25 pm
Is the feature not there in PCDJ ? In setting, is there a BROWSER tab?
geposted Sun 29 Jun 08 @ 5:38 pm
Nope...no browser tab.
geposted Mon 30 Jun 08 @ 1:28 am
@dj-in-norway
No this feature is not included in PCDJ VJ (in fact there is no "browser" panel at all) because it's an advantage of VirtualDJ
But it's very easy to create an external tool:
1) Open the .xml database
2) For each <Song FilePath=""> </Song>
3) Verify that this file still exists on your HD
4) If it doesn't exist : remove the current <Song></Song>
5) go next <Song></Song>
5) Close the .xml database
geposted Tue 01 Jul 08 @ 4:15 am
