Topic: Karaoke How To
How Do You Display Only The Lyrics On A TV Without Display The Entire Desktop. I Have An S-video Out And An HDMI Out On My Laptop. I Have No Idea How To Make It Work.
geposted Sun 29 Jun 08 @ 10:15 pm
If your laptop doesn't convert over to dual display automatically when you plug your cable in then you would have to manually do it. When thats done you have to go into VDJ- config- video - video drop down choose which video card you want to use, ie... window or your video card then make sure the video checked. Your gonna see a quick software flash letting you know it's converted and there you go.
i did do all the steps and now the program won't play the music. the play button is lit and it says that it is playin but its really not.
go into config > sound set up, and check your options have not been changed...
