I run 5.1 with XP... On the sample..you have a volume, Each time I open VDJ the volume is off...Can I lock the volume full on? Thanks For The Help!!
geposted Tue 01 Jul 08 @ 7:02 pm
The volume should remain at the same levels when you switch over to the sampler screen. They should lock in the same setting as previously used.
geposted Tue 01 Jul 08 @ 7:13 pm
every time I log out of VDJ...the sample volume is full on... when I log back into VDJ the sample volume is off...I want it full on..I don't know how to get the volume to stay on... this is just on the sample volume not the volume of the song playing..
geposted Tue 01 Jul 08 @ 9:43 pm
Sorry dude, I tried to get the sampler setting to change but it stays where I place them. I don't have a clue as to what is happening with yours. I even tried with two different computers.
geposted Tue 01 Jul 08 @ 10:28 pm
When you start VDJ is your sample volume on or off? I'am still trying to fix it...thanks
geposted Wed 02 Jul 08 @ 9:47 am
Try adjusting the volume, then re-saving the sample under the same name.
geposted Wed 02 Jul 08 @ 10:22 am
Just to make things clear. Are you saying when you start VDJ the sampler volumes levels are down at low levels then you have to slide them up for peakness. When you exit VDJ and re-enter the levels are down at the bottom again.
geposted Wed 02 Jul 08 @ 8:50 pm
When I start VDJ the sample volume is off, I turn the volume up then save or log out of VDJ ... when I start VDJ back up, the volume is back to off...I have to turn the volume of the sampler up each time I start VDJ.. I don't know how to save it when I start-up. I think I need to re-install VDJ
geposted Thu 03 Jul 08 @ 6:52 am
Hmmmm, that is strange. I would try re -installing. I had to do that once when I found i couldn't record to HD... It cured the problem.
geposted Thu 03 Jul 08 @ 9:58 pm
I re-installed VDJ.... so far things look good.... the volume stays up when I close out of VDJ....Thanks... to all
geposted Sat 05 Jul 08 @ 7:48 am
