Has anyone had any problems with playing some Xvid encoded videos where the video is a couple of seconds ahead of the audio? I'm sure it is probably just codec issues for me, so I think I will try to re-install them, but just in case I thought I would throw the question out there. And it doesn't happen on all videos, just a few. If the devs need a sample, PM me and I will post it on my website for download.
geposted Thu 03 Jul 08 @ 6:22 pm
Check the plugins, sure there is something on Xvid, maybe wrong though.
geposted Thu 03 Jul 08 @ 6:26 pm
Have you tried playing the videos in Windows Media Player (or your default player of choice) and do the problems still exist? If they do, you can also try VLC which uses its own codecs independent of the system to test if it's a problem with the files.
geposted Thu 03 Jul 08 @ 6:36 pm
Love VLC, use it all the time. In fact, that is what I preview videos with while at home. And yes they play fine on everything else. (Both Xboxs and the PC) Also note, it doesn't happen on all of them, just some.
geposted Thu 03 Jul 08 @ 6:40 pm
Hello all im having a issue when im mapping or loaded a new song to play and the program locked up and i have to restart any suggestions??
geposted Thu 03 Jul 08 @ 9:23 pm
Please don't hijack the thread. Kindly start a new topic for your issue.
geposted Thu 03 Jul 08 @ 9:31 pm
