I've been a Virtual D.J. user for about 3 years, but on Windows machines only. I have a new MacBook Pro.
Tonight, I installed the latest Hercules drivers for my RMX, and installed VDJ for Mac 5.07. All seems to work well so far, but I have a couple of (probably) really basic questions, as I'm used to Windows versus the Mac OS.
1) How do I scan my files. In Windows I would right click for a menu - does the same menu appear in the Mac version somewhere?
2) Where do I put new skins? I'd like to use the vmix skins, as they're widescreen, and get more usage out of my screen.
3) Is there a pdf manual for the Mac version(s)?
Thank you!
Thank you!
geposted Fri 04 Jul 08 @ 2:46 am
You have to use MAC 5.0.8 if you want to use the RMX
1) Yes it is the same
2) Go to your documents then you have a VirtualDJ folder. It's like the Windows version
geposted Fri 04 Jul 08 @ 1:15 pm
to scan your files just push ctrl and click with your mouse and the right menu it will be shown
geposted Tue 08 Jul 08 @ 4:07 am
