I currentlly have the hurcles mk2. I use w/ vdj 5.06 as a controler and sometimes as a sound card for tccd. I love the way it works. I am thinking about going totally digital so i dont have to carry around cd, and cd players. If i do that I will need something for back up. I currently carry to loaptops and one external hd to every gig. So I was thinking about getting a new second contoler. Sould I just get a second mk2 for 249 that works well for me or should i get the rmx 349. I f i get a rmx and download the drivers do i have to update vdj to 5.1 and will my mk2 still work w/ all the updates please give advice. thanks in advance.
geposted Fri 04 Jul 08 @ 9:34 am
RMX mate, I've got both, I love both, but I have to say the RMX is much better. If you go with the RMX I think you should download 5.1 and the new Herc driver package for the RMX and you'll be sorted.
geposted Fri 04 Jul 08 @ 9:44 am
thanks jimmy b will 5.1 work w/ the mk2 also ?
geposted Fri 04 Jul 08 @ 12:51 pm
Yes, it is natively supported.....
geposted Fri 04 Jul 08 @ 12:52 pm
