Hi,
I`ve just upgraded from the RMX version of VDJ to the Pro version, But I can't find the RMX Skin in the Skin's menu? It was there in the LE version.......?
Cheers,
Nelse
Cheers,
Nelse
geposted Sat 05 Jul 08 @ 11:01 am
Nice one, Welcome aboard mate, There won't be mate, that skin is just for the console edition.
geposted Sat 05 Jul 08 @ 11:08 am
Thanks......
Is there an easy way to change the effects on buttons 1-6 then?
geposted Sat 05 Jul 08 @ 11:10 am
Go to the Remote control tab of the config, Right click on the mk2 icon, it will bring activate or config, click on that and you will see the buttons in a list follow the pointer and see the actions you can change.
It's only basic, or you could go the the download section and grab the 6 button mapper by moramax, that has alot more actions in it.
geposted Sat 05 Jul 08 @ 11:15 am
Thanks...........
geposted Sat 05 Jul 08 @ 11:16 am
