OK SO I HAVE MY RMX, VIRTUL DJ 5.1, AND A 12 CHANNEL MACKIE MIXER CONNECTED WITH SOME 15 INCH JBL'S ON STANDS...THE ONES THAT ARE SELF POWERED! ITS A VERY GOOD SETUP...I LOVE HOW IT SOUNDS AT PARTYS!...NOW...I WANNA CONNECT SOME TURN TABLES TO SCRATCH ....HOW CAN I CONNECT THEM TO THE RMX OR WAT DO I NEED TO CONNECT AND START SCRATCHING....PLEASE HELP... DO I NEED THE VYNIL CD'S???????
geposted Mon 07 Jul 08 @ 9:22 pm
try searching before posting.....here's something that would've come up
geposted Mon 07 Jul 08 @ 10:27 pm
If they are vinyl turntables, then you can order the TCV's from this site, if you mean CDJ's then you can download the timecode signal from the site and burn it to CD.
geposted Tue 08 Jul 08 @ 12:22 am
