Would it be possible to make vdj compatible with this technology?
http://www.bluetooth.com/products/
Andre
Andre
geposted Mon 10 Jan 05 @ 6:51 pm
what do you mean by compatible? what would you want to do with it?
geposted Sun 16 Jan 05 @ 10:30 pm
Apart from what would you want to do with it other than use your bluetooth enabled PDA or Smartphone to control VDJ, I think you would experience reliability issues mainly latency with BT
geposted Mon 17 Jan 05 @ 2:15 am
I want to know if i can use this for work so i could be wireless (but i guess you are right there will be a big amount of latency)
Andre
Andre
geposted Mon 17 Jan 05 @ 8:36 pm
It would be a great idea... i saw some guy on a party, his computer has been locked (password on windows), and he was sitting 30m from the computer and playing music over his PDA (bluetooth)...
He did'nt using VDJ, i thing he was using WinAmp... If it's that simple that winamp can use Bluetooth, why not Virtual DJ?!!?
If you implement this, i will by both, bluetooth and VDJ :)
geposted Tue 18 Jan 05 @ 1:27 pm
that doesn't necesarilly mean he was using bluetooth infact it's more than likely that if he was using Winamp it would have just been a wireless 802.11b pda on pocket pc.
geposted Wed 19 Jan 05 @ 2:18 am
