I don't know if is just me...!
i have try all setting with the AVI codecs i have get from other websites expensives encoders that it works by it self..!
but they don't work with VDJ video recordin,even if i'm using the regidtry tools to set-up the configuration of each codecs
VDJ it does not let this encoders to work!...
Any one have some suggestion..?/
Thank you ! Gino Roggiero
geposted Sat 19 Jul 08 @ 12:41 am
I also can't find anything here in the forum so far about what Codecs to use. I really would appreciate the help. I have the new version and I am a real user.
geposted Tue 05 Aug 08 @ 8:46 pm
Some codecs are limited to 320x240 that's why the Microsoft MPEG4 encoder was used by default
geposted Wed 06 Aug 08 @ 7:12 pm
Im using two paks. Divx pak and the k lite codec pak. With there you should be able to record in any format and size you want. I use Divx. If you don't know install the divx codec, and in the format area type divx and see what happens.
geposted Fri 08 Aug 08 @ 9:38 pm
the best setting was divx in 1080 HD set at 3 at 7000,but after recording i still have to re-encode the file to make it work with any video player...using Pegasys TMPGEnc 4.0 XPress
the defaul codec MPEG4 never start....
geposted Sat 23 Aug 08 @ 6:48 am
