Hi. I just tried to play some videos from Venue and it appears I can not play them, what decoder do I need in VDJ or a link to one. Thanks
geposted Tue 22 Jul 08 @ 3:24 pm
I've never heard of a video file with that extention. Perhaps this is part of Venue's DRM DEVIL?
geposted Tue 22 Jul 08 @ 4:34 pm
Sorry to Hijack
@djrenee, just seen you've been given one.............. a star I mean, lol. Welcome to the Exp. user's club
geposted Tue 22 Jul 08 @ 4:39 pm
VenueVJ videos are directly supported in VirtualDJ Pro v5.x
If you look in the Config - Codecs tab you will see the .vix extension and it should be associated with the Video Decoder.
If it is one video then it most likely is a bad download from VenueVJ. If it is all of your downloads then you may wish to redownload the latest version of VirtualDJ and reinstall.
geposted Tue 22 Jul 08 @ 4:46 pm
JimmyB I just received an e-mail from a TEAMER saying my brand new fourth star was going to be revoked because I did not know what a dang .VIX extension was. :-(
geposted Tue 22 Jul 08 @ 5:09 pm
djrenee wrote :
JimmyB I just received an e-mail from a TEAMER saying my brand new fourth star was going to be revoked because I did no what a dang .VIX extension was.
LOL, but we Know now thanks to Chris.
geposted Tue 22 Jul 08 @ 5:16 pm
I did not see this in my list, on either machine.
geposted Tue 22 Jul 08 @ 5:19 pm
Hi. Thanks for reply. I checked the list of codecs also before the post, should of stated that, but I looked again, and d/l 5.1 again and re-install, nada. No searches showing up really on forum about .Vix either :( Tried google, but after the 15th page, gave up. Also my other 2 laptops do not have it.
geposted Tue 22 Jul 08 @ 5:41 pm
Then add the vix extension and assign it to the Video Decoder
geposted Tue 22 Jul 08 @ 5:45 pm
Thanks alot. Works now.
geposted Tue 22 Jul 08 @ 5:55 pm
How do you do that, for future reference.
geposted Tue 22 Jul 08 @ 5:56 pm
Go to Config -
Go to Codecs
Click on ADD
Enter VIX in the Extension box
Select Video Decoder from the drop-down
Click OK
Go to Codecs
Click on ADD
Click OK
geposted Tue 22 Jul 08 @ 5:59 pm
Cheers for that, will be needing that I think when VenueVJ hit's the UK shore's.
geposted Tue 22 Jul 08 @ 6:09 pm
