So my wife tossed my RMX box which had my CD and License code in it.
Do I contact VDj or Herc for a replacement?
Thanks - h
Thanks - h
geposted Tue 22 Jul 08 @ 3:47 pm
Try this, Go to Downloads>Software updates.
Enter password in that you use in the forum. You should then see you serial number for your home version, also you can downloaded it from there if you have too again.
geposted Tue 22 Jul 08 @ 4:11 pm
?? It says "No License Found"
geposted Thu 24 Jul 08 @ 8:46 am
Well, you must off put you serial number somewhere on this website, so you could be registered as a Home user,
Contact the team, via a ticket, I'm sure they'll have a copy of your serial number.
geposted Thu 24 Jul 08 @ 9:31 am
