I'm using VDJ with the HERCULES CONSOLE. How do I make a CD of my owm mix? Can you be specific about each step? Thanks.
geposted Fri 14 Jan 05 @ 9:52 pm
hi shinobi16,
you can simply use the integrated record plugin in vdj, if you're also using a mixer, you've to link your rec-out to the djconsole line in (or an other card line in) and record with an external software (goldwave for example).
Guillaume
Guillaume
geposted Fri 14 Jan 05 @ 10:52 pm
you can also use the rip-vynil software included in VDJ since version 2.06.
desactivate the RIAA amplification and record your mix.
geposted Sat 15 Jan 05 @ 11:01 am
