What is the easiest way to set up a WndProc function in a Plugin ? I want to monitor some windows messages.
geposted Mon 11 Aug 08 @ 12:24 pm
To elaborate:
I want to monitor "WM_COPYDATA", So no strange stuff ;-)
Can i use the handle returned by GetInfo("hwnd") or do i have to create an invisible window and add it to that ? Or is there any other way ?
geposted Mon 11 Aug 08 @ 12:51 pm
What window are you trying to capture the message from - surely it would have to be the target control of the original SendMessage() call, which means you would have to have created that control, and thus already have a callback function attached to handle it's messages?
geposted Mon 11 Aug 08 @ 3:15 pm
The best would be if i could attach it to the main VDJ window and use the handle i get from GetInfo(). Can i setup a WndProc function, attach it to the main VDJ window in a plugin ? Or do i have to create an invisible window and use for this.
It's my code that generate the SendMessage() from another process so i just a need a WndProc function with a valid handle in the Plugin to Send it to.
I'm still testing different IPC methods with VDJ to evaluate the best one for my use.
geposted Tue 12 Aug 08 @ 12:44 am
If it's only to get message, try something like this. I didn't test it but maybe it's enough in your case
Do not use the function "PeekMessage" instead of GetMessage() because PeekMessage will use your CPU at 100% with the "while" whereas it's not the case with GetMessage()
The NULL of GetMessage is a HWND
MSG msg;
while(GetMessage(&msg,NULL,0,0))
if(msg.message==WM_XX)
// your code
geposted Tue 12 Aug 08 @ 6:59 am
Doesn't that take a lot of CPU ? A WndProc must be better, or ?
geposted Tue 12 Aug 08 @ 12:33 pm
A WndProc uses the same system. It's common for all the window to communicate: loop of MSG
MSG msg;
while(GetMessage(&msg,NULL,0,0)==TRUE)
TranslateMessage(&msg);
DispatchMessage(&msg);
geposted Tue 12 Aug 08 @ 2:00 pm
ok , well i will do some testing .....
geposted Tue 12 Aug 08 @ 2:03 pm
