Can you tell me something about the bypassing of VDJ when using timecode? I need to be absolutely sure it works before i'm going to use it. Is the use of normal vinyl 100% safe when using bypass? Are there any known stability issues?
geposted Tue 12 Aug 08 @ 4:41 am
I've tried it 3 or 4 times at home, but never live at a gig.
All I can tell you it worked, but watch the volume I noticed that "normal vinyl" was loud compaired to the mp3/timecode tracks.
Why don't you have a go at home and see for yourself.
geposted Tue 12 Aug 08 @ 6:06 am
I don't have technics at home. They are on my rider. I'll see, i do have some cinch splitters, so i might use that.
geposted Tue 12 Aug 08 @ 8:03 am
It works really well with real vinyl. I use it 3 or 4 times in a gig without any issue.
geposted Tue 12 Aug 08 @ 9:09 am
Same here, use it alot and I stopped having auto gain issues with 5.1 and 5.2, the sound quality is not affected at all.
geposted Tue 12 Aug 08 @ 10:50 am
