is there any vdj skin editor or how is it possible to edit a vdj skin?
geposted Fri 22 Aug 08 @ 6:06 am
Not that I'm aware of, but editing a skin is very easy to do - just edit the bitmap and XML according to what you want to do. For example, moving an element in the bitmap - move its co-ordinates in the XML file to correspond.
geposted Fri 22 Aug 08 @ 8:01 am
hmm only so simple? if i deleted something in bitmap and then i saved it, then i put both files in a rar file and put em in the skin directory but VDJ wouldnt load em, neither in the skin menu :S
geposted Fri 22 Aug 08 @ 8:13 am
You don't have to compress them, but if you do, put them in a zip.
geposted Fri 22 Aug 08 @ 9:06 am
this may help... or not, lol
geposted Fri 22 Aug 08 @ 9:07 am
Hi to all
I'm currently working on a skin editor. It is still in development stage, but should be released some time in September.
Current features:
-Open XML and Graphic file at the same time
-Magnifying of the picture, up to 1600%
-XML syntax highlighting
-Automatic XML indention
-Make a selection in the Graphics, choose an element in a dropdown box (slider, button, textzone, visual, ...), edit the definitions of the element, right-click on the selection to automatically write the XML code for the element.
-Select some XML code, rightclick on it to automatically make a selection in the graphics to see where is the element
-Auto-save feature to prevent loosing data
-Two click XML making. From a blank xml, make a skin that can be used in a few seconds.
-Automatic opening of files, if you open the XML or graphic file, the corresponding file is also opened.
Current features:
geposted Fri 22 Aug 08 @ 11:31 am
eagerly anticipated...
geposted Fri 22 Aug 08 @ 12:01 pm
The skin editor sounds great,I hope you will make it open for download to all users.ie (home edition users)?
geposted Mon 25 Aug 08 @ 9:25 am
JeremK, you are the bomb.
all hell will break loose once that skin editor comes into play.
does it support cloning buttons and knobs too?
for example: copy the key knob of deck A to deck B
DJ Shahar
DJ Shahar
geposted Mon 25 Aug 08 @ 9:19 pm
