Does anyone know how to disable smart_scratch in version 5.2?
geposted Sat 23 Aug 08 @ 11:18 pm
I believe all you need to do is create a keyboard shortcut to toggle it on and off.
geposted Sun 24 Aug 08 @ 3:00 am
I tried creating a keyboard shortcut and it does not have any effect. Do you know what value to use when creating a shortcut for smart_scratch?
geposted Sun 24 Aug 08 @ 3:34 am
Actually I don't, I am sure someone will be along to answer who knows:)
geposted Sun 24 Aug 08 @ 3:39 am
You jusr create a keyboard shortcut for smart_scratch, and specify the deck you want it for. I creted two shortcuts, one for each deck, using the same key to act as a global toggle. Leave the value unset.
You can also create a skin element, this will show you its current status.
geposted Sun 24 Aug 08 @ 7:14 am
