Can anyone tell me how to make the show cover plugin work, I can't get it to work when i try to use it, it says error to reinstall the plugin. Can some tell me how to install it step for step. I know there is two shover cover plugin, where do i put the content of the second show cover plugin.
geposted Sun 07 Sep 08 @ 1:20 pm
2 plugins ??? There is only one.
Which one do you have?
geposted Sun 07 Sep 08 @ 1:30 pm
On the down load page for video effects there is two different show cover plugins, one that has the plugin, and the other one which contains a folder which contain various files, I have virtual dj pro it just wont work, Has anyone got it to work if so tell me what to do.
geposted Sun 07 Sep 08 @ 10:13 pm
