im lookin for anyone who can change this skin http://www.virtualdj.com/addons/4399/Turntablist_variations.html to my computer screen size. if u want more info contact me at my email. antonio145@aol.com. i tried it my self but it came out mess up and i had no idea what i was doing. thank you.
geposted Mon 08 Sep 08 @ 5:56 pm
Think there already is such a version
if not, use Jerems skin resizer tool ;) works wonders
http://www.virtualdj.com/forums/90622/Skins/VirtualDJ_Skin_Resizer_Tool_(Version_1_2).html
(for home edition and above only... )
geposted Mon 08 Sep 08 @ 6:35 pm
i tried that but my skin came out way wrong.
geposted Mon 08 Sep 08 @ 6:38 pm
JeremK is usually more than willing to help, especially if the resizer does not work for some reason. Have you posted in the skins forum about the resizing issue?
geposted Mon 08 Sep 08 @ 9:46 pm
Well there is no resizer yet that will do anything for round objects.
As it turns out i just so happen to have a 1024x768 of the original turntablist skin, so if i can resize this one then all i have to do is re-add the spinners since my graphics are all ready done ;)
When you tried to resize this what happened? is everything ok but the spinners? if so PM me with a download link of the .zip so i can fix it quickly.
geposted Tue 09 Sep 08 @ 8:07 am
