Forum: Wishes and new features
Topic: about effects!
Well, i've been playing to "wider" audiences with this soft, and... well, since there's not enough punch using mp3s and the sound quality sometimes it's not perfect (frequency ranges and so on) it's hard to keep the people moving, so....
Can we have a compressor ? i'm actually using an external compressor unit and yeah!, that's something!!!
What about some "general effects slot"? i mean, some effects can be used on both decks (like eq) and using that slots you can modify the whole sound not just on one deck.....
thank you
geposted Sat 22 Jan 05 @ 4:08 pm
You can use VST compressors; check the VST section on the forum about these possibilities.
To add the number of slots in the effects you can use a bar ravelling ("barre défilante" in French) as when you choose your effects before drag n drop.
Yea. i think a general effects section would be helpful, as he is right.. mp3s do loose some punch :S
@ djcel.. i'm a bit confused with what you mean.. can you explain it again please?
Sorry, I knew my expression wasn't right. Maybe ScrollBar (this is the computer science word) to designe the way to go up and down in a big list when the windows have a little size
