Hello,
Is the NS7 is completely compatible with virtual dj??
I mean for example like the total control that is ''plug and play''.
Im asking because I saw the latest version of virtual dj and on the setup/remote control tap is not the icon of the ns7 to activate.
geposted Sun 21 Sep 08 @ 3:06 am
At this time the NS7 is not natively supported. It is possible to map it using the midi function....
geposted Sun 21 Sep 08 @ 7:23 am
There was a thread about it in the Gen forum, maybe terry or another mod can dig it out for you.
geposted Sun 21 Sep 08 @ 7:41 am
If you have 30 minutes then that is what it would take to map this to the software its really easy and lets you make it more to your needs.
geposted Sun 21 Sep 08 @ 3:14 pm
another thing do you think that in virtual dj's future versions 5.3 or 5.4 ... thw ns7 will be mapped out? I mean with the icon to activate.
it should exist the possibility right? if the ns7 work with serato but its also from numark, and numark has cue and cue and virtual dj is basically the same.
geposted Mon 22 Sep 08 @ 10:29 am
Even though the NS7 comes with Serato itch. for audio, its better to use itch because the NS7 was designed to work perfect out of the box without any configuration.
geposted Tue 23 Sep 08 @ 8:28 pm
Its the NS7 already released?
geposted Wed 24 Sep 08 @ 3:12 pm
ohh, but the thing is i also dj with music videos and serato only supports music. also i would like to have more hands on control i have a total control and work super cool but for scratching and mixing the buttons are so close to each other that is kind of uncomfortable some times. i looking for a better control but dont want to have to carry some the pioneers using time codes. ill prefer a usb controller any suggestions??
geposted Thu 25 Sep 08 @ 12:23 am
hey! i just send numark (technical support) an email talking about this topic, as soon ill get the reply i will post it :)
geposted Thu 25 Sep 08 @ 12:41 am
@King
The controller will control any software such as Virtual DJ or your chosen VJ app via midi.
geposted Fri 26 Sep 08 @ 3:44 pm
Hmm at least I read this:
The NSNS7 Controller is a dedicated controller for Serato™ ITCH. It ships with Serato™ ITCH and comes ready to control the DJ software of your choice, including Serato™ ITCH
and Numark’s CUEUE DJ software.
in this pdf:
http://www.numark.com/stuff/contentmgr/files/6/9f2db1fc64e2f7b21158a83bef7f0804/file/ns7controller_2008_numark_productoverview.pdf
(deeplink may expire because of session)
in this pdf:
geposted Fri 24 Oct 08 @ 4:31 am
Isn't going to run high speed midi like the VCI?
-David
-David
geposted Wed 21 Jan 09 @ 2:57 pm
-David
-David
There are two scales available for software's to interpret.
Actually the VCI does not send high speed midi at all its a Numark Concept which powers the motorized jogs.
The VCI sends standard midi messages.
geposted Fri 23 Jan 09 @ 6:16 am
so waiiiiit is there any way of getttin virtual dj 2 work on the ns7???
geposted Wed 03 Jun 09 @ 5:51 pm
No ...
Topic Closed
geposted Wed 03 Jun 09 @ 7:38 pm
