Yup yup,
by popular request. there is now a key slider.
tell me what you think.
and any minor add-on\'s that should be added.
OverFlow Ex 1.1
i've just submitted the skin. as soon as it's up there, i'll let you all know.
OverFlow Ex 1.1
geposted Sat 27 Sep 08 @ 4:34 pm
that was fast.
you can download the new skin here..
http://www.virtualdj.com/addons/4969/OverFlow_Ex.html
geposted Sat 27 Sep 08 @ 4:39 pm
Hi djkz
Can you please tell if this skin is an update of this http://www.virtualdj.com/addons/4610/OverFlow_variations.html or this http://www.virtualdj.com/addons/4611/OverFlow_EX.html ?
To update a skin version please use this
button!
button!
geposted Sat 27 Sep 08 @ 5:33 pm
it's an update.
i thought i clicked on the update button.
sorry.
yes! this is an update.
sorry.
geposted Sat 27 Sep 08 @ 7:14 pm
Ok, I have deleted old versions, v1.1 is here http://www.virtualdj.com/addons/4969/OverFlow_Ex.html
geposted Sun 28 Sep 08 @ 2:29 am
hi guys is there anyone who can tell me if i can resize overflow skin to 1280x800 thanks anyway
geposted Wed 01 Oct 08 @ 1:30 pm
you can,
the question is, do you know how?
for a simple version of overflow, use mixstation.
overflow is mixstation with more features.
geposted Wed 01 Oct 08 @ 6:11 pm
well thank you for your answer...but i dont know how do it(i like the overflow skin and i'd like to find out how can i change the size so it can fit to my screen)thanks anyway
geposted Thu 02 Oct 08 @ 5:24 am
@djkz
It seems the CPU meter takes alot of place in your skin, and the logo isn't really placed correctly.
You could maybe put the cpu meter at the place of the logo, make the meter longer and less high, and place the logo in the upper left of the skin.
geposted Thu 02 Oct 08 @ 12:00 pm
OverFlow should be a part of MixStation Variations
geposted Fri 03 Oct 08 @ 6:25 pm
You can try using this skin resizer tool: http://www.virtualdj.com/addons/4442/VDJ_Skin_Resizer_Tool.html
It took me a long time to create the OverFlow part and all those extra rhythm/pos pannels. there is no way i can resize it myself. Sorry.
If it's just the look you like, you can get an original MixStation skin from here:http://www.virtualdj.com/addons/53/MIX_Station_variations.html
geposted Fri 03 Oct 08 @ 6:28 pm
Thanks for the feedback everyone.
geposted Fri 03 Oct 08 @ 6:32 pm
Okay,
new update.
OverFlow Ex 1.2 .. MixStation Variation.. it\'s in the name both here and the XML file.
Big Logo button displays Owner Info. Open zip file, edit bmp file. scroll down. Add your own info and tada.
now click on the VDJ logo and your info appears.. cool huh.
new update.
geposted Fri 03 Oct 08 @ 6:51 pm
thx alot anyway your skin is super
geposted Sat 04 Oct 08 @ 11:05 am
thanks
geposted Sat 04 Oct 08 @ 5:09 pm
JeremK wrote :
@djkz
i never got your feedback in regards to the new logo location and size. look how big it is. your eyes naturally move towards the logo when looking at the screen.
u r s happy?? yes /no /maybe /tell you later.
is good no?? i think it's huge improvement for vdj recognition. i tink so.
geposted Sun 19 Oct 08 @ 2:10 pm
Yes it's much better djkz.
geposted Sun 19 Oct 08 @ 2:25 pm
thank you
geposted Sun 19 Oct 08 @ 2:59 pm
