as each effect is turned on, it affects the previously selected video effects.
having the ability to move effect layer up and down would give us more output control.
logo effect will always be on top.
text with artist - title one layer lower.
3d / 2d effects beneath that. on/off
actual video beneath that.
sonique effects with transparency level behind actual video.
etc.
point is with layers / levels, we can mix & play video effects as well as audio.
get rid of the on /off column and make it a layer box where we drag effects and sort them out by level top to bottom. and obviously allowing us to move layers up /down once set.
do you understand my idea?
etc.
geposted Fri 24 Oct 08 @ 3:30 am
This is an interesting idea! :)
geposted Sat 01 Nov 08 @ 7:56 pm
I agree that the Video FX section could be addressed. Layering would be a fantastic upgrade.
In addition, I would like to see an active state added for video fx. With sound fx, I can make a button on a skin to activate/deactivate that particular effect. When it's on, the button shows that its active. If I do the same with a video effect, it does not have the ability to show whether it is active or not.
I'm using the following xml without success:
<button action="video_fx" value="Negative">
<size width="60" height="37"></size>
<pos x="95" y="95"></pos>
<up x="1190" y="808"></up>
<selected x="1190" y="768"></selected>
<down x="1190" y="768"></down>
<over x="1190" y="768"></over>
<text dx="4" dy="12" width="50" font="arial" size="10" color="#000000" weight="bold" align="center" format="Negative" scroll="no"></text>
</button>
Up & Over work fine. Down or selected have no effect.
Thanks,
Greg
</button>
Thanks,
Greg
geposted Mon 03 Nov 08 @ 10:41 am
</button>
Greg
</button>
Greg
this sounds like a skin forum topic.
geposted Tue 04 Nov 08 @ 11:53 am
It's actually for the wishlist as it is an action not functioning properly. I don't believe there is a space on the skin forum to discuss things you'd like fixed with the software. Please direct me if I am mistaken.
Greg
Greg
geposted Wed 05 Nov 08 @ 12:32 am
You were right dj-computer.
geposted Wed 05 Nov 08 @ 5:06 pm
Thank you. Hopefully someone will look into this as it should work as any of the other buttons.
Greg
Greg
geposted Tue 18 Nov 08 @ 12:38 am
