Topic: would this work???
listen2PRO InfinityMember since 2005
this is a fully mappable usb jog wheel with buttons, i was just looking and when i grab vdj up would this device be of any use? i also have tables so i figure tcv but on a small scale, and not lug all that equipment around.
geposted Tue 29 Mar 05 @ 10:57 pm
JeremKPRO InfinityModeratorMember since 2004
Could we have a link for this device please or a description
geposted Tue 29 Mar 05 @ 11:00 pm
I have a USB jog wheel with buttons too. It's called a Contour shuttle pro. Yes I could use it with VDJ, as long as the device has software that will translate button presses into key presses (it does). I've never thought of this though, since I would really need to have two in order for them to be useful. This particular device is really made for video editing, but I suppose you could use it for whatever you wanted with the keymapper. I've never used it that way though. The device can be found at http://www.contourdesign.com/shuttlepro/
geposted Wed 30 Mar 05 @ 1:56 am
