aubs123 wrote :
that's another great skin to add to the collection
not sure if you might have missed it or already updated it
the tiny black line on the effect parameter 2 knobs
thanks again L2
thanks again L2
I didnt notice, what was the issue? I hardly use one parameter, nevermind #2 lol
Thanks guys!
I was thinking about tweaking this skin more but its damn near perfect IMO. Right now I am going to focus completing 2 new updates i have been working on. if anyone finds anymore bugs let me know and i can fix em' up.
geposted Mon 17 Aug 09 @ 3:30 pm
djpr1 wrote :
That will be the Icing on the cake.....great job
listen2 wrote :
Thanks guys.
Jimmy the horizontal waves are multi-purpose. In reality all they are is full unfiltered waves, giving you a full view. I would like to see if i can get a cue marker to appear also on the scratchwaves, currently they do not support cue visuals but i might be able to work something around it.
jimmy b wrote :
Very nice L2, especially love the large horizontal scratch panels, I'm no scratcher but I love the big waveforms.
Nice one mate.
Nice one mate.
Thanks guys.
I'm eating cake now...........thanks L2
geposted Mon 17 Aug 09 @ 7:13 pm
Invalid skin file (error line 1483 in xml)
Whats the problem?
Whats the problem?
geposted Mon 17 Aug 09 @ 10:28 pm
Whats the problem?
Whats the problem?
i'm not sure there buddy but that refers to the video crossfader.
probably will only work for VDJ not VV as of yet.
geposted Mon 17 Aug 09 @ 11:48 pm
Dam....Can i get robbed by numark any more then i already have....
geposted Tue 18 Aug 09 @ 6:40 pm
Thanks guys!
thanks again L2
thanks again L2
Thanks guys!
hi L2
will try and explain it a bit better
when you open vdj up
on the effect parameter 2 controll knobs on both deck 1 and deck 2
the black line ( level marker , leval indicator dont no wot you call it lol !!) is missing
if you look at the effect paramter 1 knobs you will no what i mean
hope it makes sence now
geposted Thu 20 Aug 09 @ 2:32 pm
i might know what you mean. It happens to alls skins. This happens for effects that they dont have 2 parametrs to adjust. For example Brake effect has only 1 parametr, so parmtr 2 is actually doing nothing and showing nothing.
To see that nothing is actually wrong about the skin, try to load an effect like Flanger, close VDJ and re open it.
geposted Thu 20 Aug 09 @ 4:50 pm
hi djdad
i get what you was saying with your answer but im afraid thats not it
heres a pic
if you then click on it with the mouse the black line will appear
the effect parameter does work when its activated
but when useing a controller and turning the effect knob the knob on the skin does not move
never had this problem before useing any of L2 skins
unless its just a problem my end
heres a pic
geposted Fri 21 Aug 09 @ 9:28 am
I didnt touch anything for the code with the effects, I believe it does that also in the default skin too. It maybe how the new skin script handles images in active and inactive states.
I'll look into it, i might be able to work something, but dont quote me.
My other skins are in the older script.
geposted Fri 21 Aug 09 @ 10:28 am
I think the script is written wrong...
You should change the commands as followed
same thing for deck 2.
Quote :
<button action="deck 1 effect 1 active" rightclick="temporary">
<text dx="3" dy="2" width="60" font="arial" size="12" color="#ffffff" align="center" format="%effectslot1" scroll="yes"/>
</button>
--- Effect dropdown ---
<button action="deck 1 effect 1 select">
</button>
--- Effect params ---
<slider action="deck 1 effect 1 slider 1" orientation="round">
</slider>
<slider action="deck 1 effect 2 slider 1" orientation="round">
</slider>
</button>
</button>
</slider>
</slider>
Quote :
...."deck 1 effect active"
...format="%maineffect"
...."deck 1 effect select"
...."deck 1 effect slider 1"
...."deck 1 effect slider 2"
geposted Fri 21 Aug 09 @ 10:51 am
ok thanks.. i'll check it out a bit later
I didnt write code for the effects, i had just relocated them from the default for my design.
geposted Fri 21 Aug 09 @ 12:10 pm
the same fault is there on the defualt skins too - Mac side anyway =)
geposted Fri 21 Aug 09 @ 4:31 pm
try that guys i think it's all set now.
geposted Sat 22 Aug 09 @ 4:59 pm
thanks L2 your the man !!
what ever you've changed it works fine now
and cheers guys for pitching in i just didn't no how to explain myself very clearly thanks
geposted Sun 23 Aug 09 @ 7:09 am
Thanks, and thank you guys for your bug hunting too.
The next thing i'd like to change in this skin is the font used in the song times. I was playing a little and LCD didnt look great at all. I will make them bigger too but does anyone have suggestion on nice clean/clear font styles?
geposted Mon 24 Aug 09 @ 12:49 pm
fixes and changes coming soon.
geposted Sun 30 Aug 09 @ 9:58 pm
i have to say i love the skin
i mixed with it for 6 hours i did have one bug i dont know if it was the skin or not when i pressed mode r it speed my song up by 10%
geposted Mon 31 Aug 09 @ 12:20 am
Thanks!
Do you mean you clicked R as in relative mode? I was doing that a bit myself yesterday off and on testing something else on the TC's and it i didnt notice anything like that.
I'll have an update this week, i'm trying to add a few things i left off from the default and other minor touches.
I'm planning also a more compact version of this skin too which will cater to timecode users. It will be pretty minimal. I'm going to try to make it half of the size it currently is.
geposted Mon 31 Aug 09 @ 9:11 am
listen2 wrote :
Thanks!
yes relative mode :).
any planes to make a lager skin say 1920 by 1050 with 2 more cue points maybe more fx
geposted Mon 31 Aug 09 @ 7:23 pm
L2 mate,
I noticed something on this skin when I used it on Saturday night at my bar gig with my RMX. When I moved the pitch sliders on the RMX, the pitch slider on the skin went the opposite direction.
On all the skins I've used, when you + the pitch the slider on the RMX the skin slider moves down, when you - the pitch on the RMX on the skin slider moves up. On this skin it's opposite, + the pitch and the skin slider moves up, - the pitch it moves down. Which means it's out of sync with the sliders on the RMX (if you know what I mean, lol)
Is the skin pitch sliders designed this way, if they are, it's a bit confusing mate
geposted Tue 01 Sep 09 @ 7:58 am
