Topic: Version 2.0
Where can I get the 2.01 version since it didn't have any problems?
geposted Tue 19 Jul 05 @ 11:26 pm
NebulaPRO InfinityMember since 2004
geposted Tue 19 Jul 05 @ 11:39 pm
bagpussPRO InfinityMember since 2003
Write to E-service, and they will make it avaliable to you for download.
Hey Bagpuss..... 3 secs!!!! Whoa! thats pretty cool lol :oD
geposted Tue 19 Jul 05 @ 11:41 pm
yep :).
You should make make us aware of your problems!, because most problems that people encounter with 3.0 can be solved, it would be worth doing this.., because version 3.0 is the best version avaliable.
So please, what are your problems?, your system specs? etc.
your operating system, running proccesses, harddrive cleanliness, VDJ settings, external hardware (including controllers) all have a MAJOR effect on how VDJ runs besides system specs.
Bagpuss
geposted Tue 19 Jul 05 @ 11:46 pm
My problem is that alot of times when I load a new song there is skipping from the current track playing... I heard that v2.0 did not do this
geposted Fri 22 Jul 05 @ 12:19 am
JeremKPRO InfinityModeratorMember since 2004
What are your PC specs? It seems that your computer lacks of RAM or something if it skips.
geposted Mon 25 Jul 05 @ 2:01 am
djcelPRO InfinityModeratorMember since 2004
Currently VirtualDJ shouldn't skip with the audio part so if it goes on there is a setting to do
geposted Mon 25 Jul 05 @ 9:06 am
