I put a new version up sooner then I was going to since a bug was corrected.
o - fixes a bug where on occasion nothing would show up until you switched thumbs
o - FLV playback is smoother but uses a little more CPU. It may be hard for you tell on some videos with noise but trust me its smoother.
o - Has VDJ parameter support but its not complete yet
You can get the new version here:
http://www.pangolinplugins.com/pages/products/essential-flash.php
If you want to test out the VDJ parameter support I have a simple SWF that only records some of the parameters. This is just cheap test case I use. I will do a better one later.
Parameters.zip can be found here:
http://sms.pangolin.com/samples/Parameters.zip
As always, your current thumbs will be saved in ..\VideoEffect\Pangolin\LastActiveSaved.pak but if you want go ahead and save your current thumbs if you haven't already before you install new version.
Don
Don
geposted Mon 21 Mar 11 @ 7:36 am
For information only about Parameters.swf
"Play Length" and "Play Position" are displayed in number of samples
(sampling frequency of VirtualDJ is 44100 samples per second)
in clear : "Play Length / 44100" gives the length of the song in seconds
"Play Length" can be negative between -44100 (ie -1ms) and 0 : it was something requested by scratch DJs for not missing the first beat.
"Beat Position" (float) is the position compared to the beats in the song (so each integer value corresponds to the beat)
("Beat Position" can also be negative on the area -1ms => 0ms)
@Don
To define a little space of length "len" (in general len=0.25f is ok => 1/4 beat) on and just after the beat, you can use:
@Don
HRESULT hr = GetInfo("BeatPos",&beatpos);
float fbp = beatpos - floor(beatpos);
if(fbp>=0 && fbp<len)
// do what you want here
geposted Mon 21 Mar 11 @ 4:19 pm
Thanks for that info djcel.
Any word on the format of VideoSound values ?
Since those samples can be below -32767 or above 32767, could it be that each sample is a packed stereo pair into an int ?
Also, earlier I put up RC-7, and right after that i put up RC-8 and passed out... RC-8 corrects some weirdness in Win 7.
So if you have RC-7 hit the download link and reinstall please and you will have RC-8.
Don
Don
geposted Mon 21 Mar 11 @ 7:44 pm
@Don I sent you a message.............
Huey
Huey
geposted Wed 23 Mar 11 @ 10:17 am
I confirm you
512 packed stereo pair into an int (in other words, 1024 interleaved mono short).
geposted Wed 23 Mar 11 @ 2:48 pm
