Soon...
![](/image/75024/138628/VirtualDJ 8 - Pads version.png)
![](/image/76247/138630/Virtualdj pads 2.png)
geposted Sun 08 Jun 14 @ 5:04 pm
Looking forward to coming soon
![](/image/37115/138638/ab7ac4427cc526084aac61d563f1591a.jpg)
geposted Sun 08 Jun 14 @ 7:02 pm
Audio Mode
![](/image/52819/138668/Audio Mode.png)
Video Mode
Video Mode
![](/image/96275/138669/video Mode.png)
geposted Mon 09 Jun 14 @ 3:35 am
Here is the deal....
I am going to release one version for each controller that has a 4X2X2 Pads Matrix, so there will be a version for the DDJ-SX, DDJ-SR, DDJ-SZ, NS7II and probably a few other popular ones.
The main difference between these versions will be of course the different Pad modes that each one of them has.
the DDJ-SZ will be the first one that will come out and the others will follow shortly. Each time you press one of the Pad Mode buttons or the SHIFT on the controller, the Pads on the skin will show you the assigned action and the different actions for the PRM side buttons.
For the Fx section, the skin will also follow the Single or Multi FX Mode that you select from the controller, so it will show you 1 FX slot at the Single FX Mode and 3 FX slots at the MULTI Fx Mode.
There will be an option to hide Covers and the HotCues will offer 3 different views (to see Times, beats, names etc)
geposted Mon 09 Jun 14 @ 3:39 am
DDJ SP1?
geposted Mon 09 Jun 14 @ 8:40 am
Glad to use it with my DDJ-SR.
geposted Mon 09 Jun 14 @ 10:19 am
Reloop terminal mix 8 por favor ?
geposted Mon 09 Jun 14 @ 3:05 pm
DDJ-SP1, yes. It will come too.
TM8.. hmm that will be tricky, not because of the normal Pad modes, but for the Dual Mode. I ll have to check if the Dual mode sends any specific data so that the skin understands that.
geposted Mon 09 Jun 14 @ 3:12 pm
ok gracias
geposted Mon 09 Jun 14 @ 3:18 pm
Looks nice and could do with a version 8 skin for the ddj-sx! Thanks in advance
geposted Wed 11 Jun 14 @ 8:32 am
DJ Dad, is it possible to make skins with a lock function like the multi skins and with option to do away with wave.
geposted Wed 11 Jun 14 @ 4:48 pm
The first version is ready. Its for the Reloop Terminal Mix 8
Download Link
http://www.virtualdj.com/addons/16789/VirtualDJ_8_-_Pads_-_Reloop_TM8.html
![](/image/39983/138999/skinlogo.png)
Notes :
- Make sure your version is updated to a build ending at .682 or later (with some changes in the mapping files)
- Dual Pad modes is supported. Actually its a perfect match for the updated default mapping
Most likely next will be the DDJ-SX (the DDJ-SZ will have to wait for a while as we will update the mapping files shortly)
Download Link
Notes :
geposted Thu 12 Jun 14 @ 5:11 am
1 request though, when you get to the DDJ SP1 I want the "Loop Roll" to effect the video as well please.
Still boogles my mind why it doesn't work that way anyways.......
geposted Thu 12 Jun 14 @ 12:09 pm
Stupid question - do you have to use it with the controller listed? I have a VCI-400 and quite like the look of this.
geposted Fri 13 Jun 14 @ 2:44 pm
You can use it with whatever controller you want. But the PADs will follow automatically only the controller that has a specific way of functions/actions (which in this case its the Terminal Mix 8) so i am not sure if this will fit with your VCI.
geposted Fri 13 Jun 14 @ 8:34 pm
the Pioneer DDJ-SX version is now available
Download Link : http://www.virtualdj.com/addons/16791/VirtualDJ_8_-_Pads_-_Pioneer_DDJ-SX.html
![](/image/99179/139188/skinlogo.png)
geposted Fri 13 Jun 14 @ 11:11 pm
and the Pioneer DDJ-SR version as well ..
Download Link : http://www.virtualdj.com/addons/16792/VirtualDJ_8_-_Pads_-_Pioneer_DDJ-SR.html
![](/image/85498/139193/skinlogo.png)
Next, ... possibly NS7II
geposted Sat 14 Jun 14 @ 12:07 am
Great job DjDad, you kill it bro'. Thanks for all.
geposted Sat 14 Jun 14 @ 11:34 am
Thanks "djdad." The SR skin is perfect for my DDJ-SB. Thank you for all of your hard work.
geposted Sat 14 Jun 14 @ 3:12 pm
Now we are starting get somewhere. :)
Awesome stuff.
Awesome stuff.
geposted Sat 14 Jun 14 @ 11:05 pm
