thetracker510 wrote :
yeah strange.well zanard you are the master,cant you fix it? I Luv this skin.also how about some dedicated Gui buttons,you know..just the little arrow thing?
zanard wrote :
In the last video you can not see this problem ... strange ....
the mask for the image is not working in v8?...wow...can the image be cut into a circle?...basic theory,no?
You have the 1.1 update?
You changed the skin.png?
As you can see from the video, the problem does not exist....
geposted Tue 10 Mar 15 @ 4:21 pm
Brian, you have the same problem of thetracker510 with the cover?
geposted Tue 10 Mar 15 @ 4:23 pm
did not change anything zanard.wierd....will check your update again...
geposted Tue 10 Mar 15 @ 6:14 pm
just checked,still bugged...X-96 is working fine but that does not have the large images.hmm...will try a fresh install of the skin...
geposted Tue 10 Mar 15 @ 7:41 pm
Okay...its something here but dang....:p
<cover deck="left" rotate="yes" visibility="var 'cover' 1">
<pos x="55" y="220"/>
<size width="488" height="488"/>
<clipmask x="784" y="2414"/>
</cover>
<visual deck="left" visibility="var 'cover' 1">
<Tooltip></Tooltip>
<pos x="0" y="111"/>
<size width="661" height="709"/>
<off x="0" y="2301"/>
</visual>
<visual type="rotation" source="deck left get rotation" >
<size width="571" height="571"/>
<pos x="13" y="178"/>
<on x="449" y="1591"/>
</visual>
<scratch chan="left">
<mousemask x="1341" y="1327"/>
</scratch>
<visual visibility="deck left touchwheel_touch">
<pos x="40" y="205"/>
<size width="518" height="518"/>
<off x="1361" y="3966"/>
</visual>
<cover deck="right" rotate="yes" visibility="var 'cover' 1">
<pos x="1378" y="220"/>
</cover>
<visual deck="right" visibility="var 'cover' 1">
<Tooltip></Tooltip>
<pos x="1260" y="111"/>
<off x="1245" y="5970"/>
</visual>
<visual type="rotation" source="deck right get rotation" >
<pos x="1336" y="178"/>
</visual>
<scratch chan="right">
</scratch>
<visual visibility="deck right touchwheel_touch">
<pos x="1363" y="205"/>
</visual>
Also...this computer seems to change photos to higher resolutions I think...when I open some on "Logo maker" I must resize some pictures smaller and the pictures originated from my phone? but I dont get this error on other skins (probably because other skin dont have big platters like this one..hmm
</cover>
<Tooltip></Tooltip>
</visual>
</visual>
</scratch>
</visual>
</cover>
<Tooltip></Tooltip>
</visual>
</visual>
</scratch>
</visual>
geposted Tue 10 Mar 15 @ 8:07 pm
no
geposted Tue 10 Mar 15 @ 9:38 pm
geposted Tue 10 Mar 15 @ 9:39 pm
Ok my images arent showing on the forum
make sure they are png or something like that brian...I just found out some of my old clipsbank wont loop on the sampler after using the sample editor??? oh man...back to playing with FL lol.....
geposted Tue 10 Mar 15 @ 10:32 pm
Tracker .png image that occurs around the mask is white.
Brian only .png.
</cover>
geposted Wed 11 Mar 15 @ 1:00 am
No issue here
geposted Wed 11 Mar 15 @ 1:47 am
again..I have not touched this.has it changed from what you wrote zanard?.....is it that I'm downloading images that are to high in resolution.I seem to remember a thread here about something like that...if is a easy fix okay.but Im not resizing every cover I downloaded :p
geposted Wed 11 Mar 15 @ 1:54 am
Heres what I was talking about on the large browser when it comes to control and video preview windows
geposted Wed 11 Mar 15 @ 2:11 am
Any word??
geposted Wed 11 Mar 15 @ 5:01 pm
Checkin to see if there is a usable update for tonight??
geposted Fri 13 Mar 15 @ 2:04 pm
Sent now!
geposted Fri 13 Mar 15 @ 2:38 pm
Cool will look for it in a few hours when I get to work.
geposted Fri 13 Mar 15 @ 2:47 pm
cool zanard...did you find any errors in your xml? I have not touched anything ..just working on another masterpiece track I finished last night :) I will pm you...
geposted Fri 13 Mar 15 @ 3:00 pm
Sent you a pm, apparantly it wont be approved til Monday...
geposted Fri 13 Mar 15 @ 5:36 pm
Zanard,I've answered you pm's...the skin's new custom buttons are great,but what if I wanted to make them into cue 4,5,6? here is the problem.I normally delete and reposition cues by just right clickin (delete) and left clicking (assing new) this work on the standard cue (or hot cues?) but we cannot right click on custom buttons because we get the custom menu.I need more cues...would mod this Like I did in the past but I think you can do it better ;)
geposted Mon 16 Mar 15 @ 6:15 pm
