Forum: Addons
Addons comments
Topic: VDJ 8 Profiles By Djsadim - Page: 2
djsadimPRO InfinityMember since 2006
update 1.6.0.2
-virtualdj 64bit support
-automatic selection 32 or 64 version in case one or the other is absent
-add tooltip
-add clear memory button
-Add safeguards when files are missing to prevent program crash
-Fix small bugs
geposted Wed 17 Oct 18 @ 10:34 pm
update 1.6.2.0
-Add slideshow remembers position in list after being turned off and on again (sideView)
-Add remember last opened setting page (settingPage)
geposted Sun 11 Nov 18 @ 4:54 pm
Hello again,
couldn't work that out.
Anyway, now I tried to start "Profiles" Version 1.6.2, that one wont start at all. Just says "VirtualDj installation folder not found".
VirtualDJ is where it is supposed to be:
C:\Program Files (x86)\VirtualDJ\VirtualDJ8.exe
If I need to do something in the registry, kindly tell me the exact key, value and data to fill in.
Thank you very much.
geposted Thu 07 Feb 19 @ 2:32 pm
Purple Lounge wrote :
Hello again,
has the wrong value of registry (you may have installed some old version of the program later)
he checked of registry RunFolder in the HKEY_CURRENT_USER\Software\VirtualDJ
geposted Fri 08 Feb 19 @ 3:45 pm
1.6.5.0
- add remembers internal Plugin Locations position
geposted Sat 23 Feb 19 @ 6:49 pm
i test this in the next days,thanks forward to you.
geposted Fri 15 Mar 19 @ 1:06 pm
NEW
update 1.7.0.3
-harmonization with the new version 2020
-support official version vdj 64 bits
geposted Thu 03 Oct 19 @ 6:12 am
NicotuxHome userMember since 2014
Strange it writes "VDJ32-bit" at bottom right and complains about "virtualdj 64.exe program not found!" and exits
Of course because its name is "virtualdj8_64.exe" or "virtualdj8.exe"
with an Eight "8" and an Underscore "_"
HKEY_LOCAL_MACHINE\SOFTWARE\VirtualDJ only have
"home folder" which is ok
"homefolder" which is ok too
profiles are created/deleted added to memory correctly
geposted Thu 03 Oct 19 @ 7:16 am
now its official installation VDJ64 bits is in the folder C:\Program Files\VirtualDJ and not in the folder C:\Program Files (x86)\VirtualDJ, aand the name remains virtualdj8.exe in both cases
geposted Thu 03 Oct 19 @ 7:53 am
update 1.7.0.4
-Fix bugs (update pending review)
geposted Thu 03 Oct 19 @ 9:09 am
quote=djsadim]
now its official installation VDJ64 bits is in the folder C:\Program Files\VirtualDJ and not in the folder C:\Program Files (x86)\VirtualDJ, aand the name remains virtualdj8.exe in both cases[/quote
Really bad news, as update "hopefully" does not follow this official
64bit can't display any video on many systems and leak many things - specially plugins not 64bit complient for now
or maybe it would install 32bit version in "C:\Program Files (x86)\VirtualDJ" as needed
update 1.7.0.4 is a Good news though
geposted Thu 03 Oct 19 @ 1:00 pm
the bug has been found and has been fixed in the next version 1.7.0.4
Thank you for your suggestions
wait for it to be approved
geposted Thu 03 Oct 19 @ 1:57 pm
djsadim wrote :
1.6.5.0
That works fine For me in VDJ 2018,have forgot The Back Answer for You.
The New Versions Update For VDJ 2020 will Test it soon,think next week.
Thanks For your Plugin.
geposted Sat 05 Oct 19 @ 9:15 am
update 1.7.1.0
Add remembers effect banks (pluginBanks) [update pending review]
geposted Tue 24 Dec 19 @ 7:13 pm
Seite : [<<] [<]
