Forum: Addons
Topic: VDJ 8 Profiles By Djsadim - Page: 1
djsadimPRO InfinityMember since 2006
geposted Thu 15 Jan 15 @ 12:15 am
update 1.3
Add four memory locations, for direct and quick withdrawal of profile.
fix small bugs
geposted Wed 28 Jan 15 @ 12:37 pm
hello djsadim!
We i can activate this Addon Plugin?
When i start the Exe ,it write later before by Installation
this not a permissible Win 32 Bit
greatings,Dirk
geposted Thu 29 Jan 15 @ 5:20 pm
idj4himPRO InfinityMember since 2009
i REALLY LIKE this addon. works great except 1 thing. my profiles are being saved but it wont save in the memory slot. i can load all the slots but it wont save after it closes. any ideas. THANKS
geposted Fri 30 Jan 15 @ 5:21 pm
ok!
This bug has been detected long ago and FIX
update 1.3.1 pending review
geposted Sat 31 Jan 15 @ 11:43 am
thanks djsadim. i still like the addon.
geposted Sat 31 Jan 15 @ 3:00 pm
Thank you. I use different skins, audio setups etc for different projects. CooL :]
geposted Sun 01 Feb 15 @ 8:41 pm
update 1.3.1
fix bug sometimes not save in memory slots
geposted Mon 02 Feb 15 @ 12:39 am
The Plugin dont work for me :(
By the New update from 2.Februar 2015 that is the Self we before.
Does this plugin work only with Win 64 bit or so,or must the exe. in a folder from VDJ 8?
greatings,Dirk
geposted Mon 02 Feb 15 @ 11:53 am
im running win32 and 64. installed on both and both works.
geposted Wed 04 Feb 15 @ 5:19 pm
Mini update 1.3.2!
Now running in winxp without problem!
Enjoy!!
geposted Fri 06 Feb 15 @ 3:29 am
new update 1.4.4
containment Last selected folder (saved for the next session)
containment Last date from the tracklisting.txt file
containment of memory locations after new update or change the position of the program!
geposted Sun 08 Feb 15 @ 6:33 pm
Maybe I'm just to stupid, but... how does it work?
Where do I have to copy the assambly? Because every time I click on your logo in the middle of the program, or if I create a profile, add it to a memory button and click on that memory button I get a "FileNotFoundException".
geposted Wed 11 Feb 15 @ 4:50 pm
To ask a question?
You changed the name of virtualdj to something other than the "virtualdj8 .exe"
e.g. "virtualdj.exe"
geposted Thu 12 Feb 15 @ 4:08 am
Just to let you know:
I fixed it. Your program is running fine now.
It somehow changed my running folder after installing a LE Version of V7.
So your app was looking into the wrong directory.
geposted Tue 17 Feb 15 @ 3:40 am
new update! 1.5.2.0
fix create-update saving profile when it is open vdj
new 5 skin colors
geposted Tue 24 Feb 15 @ 1:09 am
update 1.5.2.1
Fix small bugs
geposted Fri 16 Oct 15 @ 10:04 am
update 1.5.3.0
- Add remember function "rootFoldersLocation"
- New function for beta testers((only for beta testers vdj)
geposted Sat 08 Apr 17 @ 4:24 am
Hi, I'm using v. 1.5.3.0, but it'll return a "file not found" error, whenever it tries to load VirtualDJ. I tried putting it in the VitualDJ folder, that didn't help. The VDJ file is named "virtualdj8.exe" so that shouldn't be a problem.
************** Exception Text **************
System.ComponentModel.Win32Exception (0x80004005): The system cannot find the file specified
at System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
at VDJ_8_Profiles_By_DjSadim.Start_Form.open_vdj_exe()
at VDJ_8_Profiles_By_DjSadim.Start_Form.BTN_LOAD_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.2600.0 built by: NET471REL1LAST
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
VDJ 8 Profiles By DjSadim
Assembly Version: 1.5.3.0
Win32 Version: 1.5.3.0
CodeBase: file:///C:/Program%20Files%20(x86)/VirtualDJ/VDJ%208%20Profiles%20By%20Djsadim.exe
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 14.7.2556.0 built by: NET471REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Win32 Version: 4.7.2556.0 built by: NET471REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
geposted Thu 28 Dec 17 @ 2:31 pm
mscorlib
System
System.Core
System.Drawing
System.Xml
enabled.
For example:
<configuration>
</configuration>
Τhe problem must lie in the fact that it does not find the file "virtualdj8.exe" in the location defined by it in the " Registry" in the value "RunFolder" this may be due
1. if you later installed the "vdj7"
2. You have changed the location of "virtualdj8.exe" from the location it had when it was originally installed
3. renaming the file "virtualdj8.exe" to something else.
geposted Thu 28 Dec 17 @ 7:31 pm
43%
