Forum: Beta Builds Regression Bugs
Topic: BUILD 2204
-Swap Ctrl+Drag and Shift+Drag to match Explorer (Copy, Move)
-Fix storing saved loops defined in seconds instead of beats
-'Stop on end' option added to backspin effect
-Fix parsing iTunes database with network paths
-Move/Delete file doesn't fail when file was still selected in prelisten
geposted Wed 15 Apr 15 @ 3:05 am
Swap Ctrl+Drag and Shift+Drag - tool tip not swapped, Ctrl says move still
geposted Wed 15 Apr 15 @ 3:32 am
It's the tooltip that's wrong. The action works as stated (CTRL copies, SHIFT moves)
It will be fixed next build.
geposted Wed 15 Apr 15 @ 9:37 am
Is it possible to have the width of the Tag Editor in Options for French User with the original language file ?
To access Color and Rating easily.
Thank you
geposted Wed 15 Apr 15 @ 12:16 pm
AsTheDJPRO InfinityMember since 2008
Waveform is not moving smooth when hitting the pitch reset from - or + .sx-2 and OSX 10.9.2 / 2.6Ghz i7/ 8Gb RAM
geposted Thu 16 Apr 15 @ 2:01 pm
gabycorreaPRO InfinityModeratorMember since 2010
I work two hours with video closes and makes this .....with the previous version worked the videos with difficulty but not close I am completely baffled not going to happen from one moment to another
geposted Thu 16 Apr 15 @ 11:19 pm
