Forum: Beta Builds Regression Bugs
Topic: BUILD 2204
-Swap Ctrl+Drag and Shift+Drag to match Explorer (Copy, Move)
-Fix storing saved loops defined in seconds instead of beats
-'Stop on end' option added to backspin effect
-Fix parsing iTunes database with network paths
-Move/Delete file doesn't fail when file was still selected in prelisten
geposted Wed 15 Apr 15 @ 3:05 am
Swap Ctrl+Drag and Shift+Drag - tool tip not swapped, Ctrl says move still
It's the tooltip that's wrong. The action works as stated (CTRL copies, SHIFT moves)
It will be fixed next build.
Is it possible to have the width of the Tag Editor in Options for French User with the original language file ?
To access Color and Rating easily.
Thank you
Waveform is not moving smooth when hitting the pitch reset from - or + .sx-2 and OSX 10.9.2 / 2.6Ghz i7/ 8Gb RAM
I work two hours with video closes and makes this .....with the previous version worked the videos with difficulty but not close I am completely baffled not going to happen from one moment to another
