Any progress on this skin please?
geposted Wed 29 Jun 16 @ 12:12 am
It must be verified by the team.
geposted Fri 01 Jul 16 @ 4:01 pm
We have something in our ToDo list, to offer the ability to assign a Remote device to a specific deck, so that this workaround will not be necessary, but dont want to keep you waiting till this is available, so we approved the skin for now.
geposted Tue 05 Jul 16 @ 6:30 am
Thanks DjDad. Eager to see this new feature!
geposted Tue 05 Jul 16 @ 12:13 pm
I successfully installed this but the skin doesn't show when looking for skins. Any ideas? Both DJ Dads skins (the original version of this and his dual deck one) show.
geposted Wed 06 Jul 16 @ 1:25 pm
In options -> Remote options, once connected to the remote app -> change/select the skin
The skins must be in the "skins/iPhone" folder.
Kaléo
Kaléo
geposted Wed 06 Jul 16 @ 1:35 pm
These are the only skins showing in the "skins/iPhone" folder. The top 2 are DJ Dad's skins and the bottom (yours) reverts to the default skin. I have successfully installed the skin a few times now and it still doesn't show?????
geposted Wed 06 Jul 16 @ 2:13 pm
I got it. I have to extract the files from the sub folders first. Thanks heaps
geposted Wed 06 Jul 16 @ 2:26 pm
Yes! of Course, and once extracted, you can choose a device number to load your skin to.
Thanks, it will give next users the trick to use it.
Kaléo.
Kaléo.
geposted Wed 06 Jul 16 @ 2:51 pm
Hey mate, just some feedback. Absolutely brilliant skin and idea. I plan to use on cheap phones and simply sit them on the top of the bland screen on cdj900's.
One glitch you should know about only with the 1024x600 versions of this skin however. On deck B2 or 2 if you leave the hotcue page you can't come back to it, the hotcue icon stays highlighted when on another page (screenshot included). The 1024x768 versions work flawlessly.
geposted Thu 07 Jul 16 @ 12:46 am
v1.1 Will correct this.
I just upload it (wait for the review).
Thanks for your feedback and sorry for this mistake.
Kaléo.
Kaléo.
geposted Thu 07 Jul 16 @ 9:26 am
Approved
geposted Tue 12 Jul 16 @ 8:07 am
Hi there! !!
I want to know what is the tablet you use for this Great Skin . Low cost tablet, I suppose.
(Sorry for my english)
geposted Wed 13 Jul 16 @ 8:26 pm
kaleo wrote :
I use a polaroïd 10.1 infinite+
The resolution is 1024x600, the screen is not really good, it needs to be well oriented but it's about 79€ and it works flawless.
geposted Wed 13 Jul 16 @ 10:50 pm
I did a Gigs last Saturday with it and I had some troubles due to the use of my phone as wifi access point -> slow fps on remotes, micro freeze...
I own a wifi mini router (https://www.amazon.com/300Mbps-Wireless-N-Repeater-802-11n-Extender/dp/B017BER4LK) and it seems to be perfect with it.
I will try it in depth this weekend and tell you about.
Kaléo.
Kaléo.
geposted Thu 14 Jul 16 @ 3:45 pm
Kaleo sorry but I put the correct link that you posted does not work
there is a ) more in the end
geposted Thu 14 Jul 16 @ 4:43 pm
I am planning to use this screen just to have two more screens (one on the left and one on the right) .
And I am looking for a vdj 8 Skin for videomix!
Then I will have audio and video screen for work ☺
Who needs 3000 euro's ew pioneer ?
geposted Fri 15 Jul 16 @ 6:06 am
geposted Fri 15 Jul 16 @ 6:07 am
Thank you,
Anyway, any wifi router should work better than a phone...
geposted Fri 15 Jul 16 @ 12:57 pm
