Hello,
I use the camera module of Virtual DJ, unfortunately this only supports Firewire and Webcams
You can expand the module so that network ip and wireless cameras are supported?
geposted Mon 25 Jul 16 @ 4:58 pm
Benz Werner wrote :
Hello,
Hello atomix team,
what do you mean to this question?
geposted Mon 09 Jan 17 @ 5:57 pm
hey, Please explain what it is you need to do? I have a few cams working at all my events. You can also make any cam that takes a full sd card into a wifi cam but buying a wifi card and then setting it up to drop to a drive or a hot spot. My hot spot is a Kingston MLWG2. It is a router and wifi plus has card slots too for instant upload. It is battery powered and can be put anywhere. You can even link it to my old I pad gen 2 and 3
geposted Fri 27 Jan 17 @ 6:43 pm
Hello Team,
I have a dance floor and would like to play the dance floor with an ip camera in VDJ (not with a webcam)
but vdj can not output IP Cam.
Please expand the camera module of VDJ for IP !!!
geposted Thu 13 Apr 17 @ 3:09 pm
Hello,
Please expand the camera module of VDJ for IP.
Thanx
Thanx
geposted Fri 14 Apr 17 @ 9:28 am
Miss this IP-Camera Plugin or a Option for this too.
was very nice when this Plugin oder Action come in VDJ
Thanks forward.
Greatings,Dirk
Thanks forward.
Greatings,Dirk
geposted Sun 16 Apr 17 @ 4:02 pm
+++1 for IP Camera !!!
geposted Sat 22 Apr 17 @ 6:33 pm
Let`s say it`s a must to have this inside the software ... This will be a big suprise for all Serato and Traktor users ...
Ohhh really with VDJ it runs even with IP cam? Damn my software is not able to do this for me. (this will be the response of a lot of VDJ haters :-) )
Come on guys we know you can add this fixture to VDJ :-)
By the way I have to say thank you for such a well software!!! Big compliment for the development team and the programmers :-)
Best regards from Germany
Sascha
Sascha
geposted Sun 23 Apr 17 @ 4:48 pm
Hello,
A work around is what tycoonentertainmentcanada already suggest. Is an easy task as long you can tell you IP CAM you would record the video in a shared folder in your computer (in the same WIFI the IP CAM is). it may have some security issues, but may worth it for what you want to do. only share this folder in your computer to get the video recordings on the IP CAM there and then you can play this on an unused deck in VirtualDJ at anytime later.
geposted Mon 29 May 17 @ 2:33 pm
IP camera support has been added to the TM 2.22 Prime version. Going direct like this assures the least amount of latency and steps are taken within TM to be sure of it.
It can be a bit awkward to determine what the proper IP link should be. Most of the time a provided link is a link to a webpage and not to a video stream.
If xxx.xxx.xxx.xxx is the IP address then:
For the Android app called IP Webcam use:
http: //xxx.xxx.xxx.xxx:8080/video
For the iPhone app called iPCamera use:
http: //xxx.xxx.xxx.xxx/live
Typically for an IP Foscam use:
http: //xxx.xxx.xxx.xxx/videostream.cgi?user=admin&pwd=&resolution=32&rate=0
note a space was left after http: so the examples would not display as links
Also I have tested with the NewTek NDI camera app and NDI in general. NDI takes the headache out of trying to determine what the IP link should be. Currently in testing. I have used it for inter program communication and as a camera app from my phone that displays on computer.
http://www.tellyvisuals.com
geposted Mon 29 May 17 @ 4:11 pm
Ok,Nice thanks for Info and make ,i will test it next time when i have more time for this.
greatings and thanks,Dirk
geposted Sun 18 Jun 17 @ 2:46 pm
when will the interface for IP cameras finally arrive?
geposted Fri 19 Jan 18 @ 10:24 am
