In the top zone of the 4 deck vertical variation, I have set the beat bar to be visible. The issue I have is the phrase sync counters are in a different order than the mixer. For the mixer, I have the order set to 3,1,2,4. The phrase sync counters are showing in this order: 1,3,2,4. How can this be changed?
geposted Thu 16 Nov 23 @ 10:01 pm
Hello,
the order of the Beat Counter on Top is in behavoir with the horizontal Wave order.
When you don't see the Main Wave Order Menu, turn on temporarily the Horizontal Main Wave.
geposted Fri 17 Nov 23 @ 7:11 am
The main wave order is set to 3,1,2,4. In the screenshot below, I've attempted to better illustrate what I am seeing. The main wave order in the center section is indeed displayed as 3,1,2,4. However, the phrase sync counters in the top section appear to be in 1,3,2,4 order. How can I change the order of the top section?
geposted Fri 17 Nov 23 @ 1:55 pm
I've encountered another issue that appears to be specific to this skin. The center mixer vumeter appears frozen unless I hover the mouse curser over the vumixer, then it updates as normal until I move the curser, at which point it freezes again. I've not been able to repeat this with the default skins, and that leads me to believe it may be something to do with a setting I've made in this skin. Any ideas on what paramater or setting would cause this behaviour?
Edit - Setting experimentalSkinEngine to 'no' in options remedied this.
geposted Wed 22 Nov 23 @ 9:14 pm
Sorry for the late awnser. I'ts a bug. I will fix it and upload an update. The booth left circles are toggled ^^
geposted Sun 26 Nov 23 @ 11:08 am
Version 3.4.3 - 2023/11/26
bugfix - the phase circle on 4 deck wrong sort. (Topzone)
bugfix - little visual correctures
add - on exit script to stop repeat scripts from the Skin
add - change the sort behavior of the Beatcounter WAVE or MIXER ("Skin Button"/Top Zone/Beatcounter sort Mixer)
change - updated the Wall of Supporter
change - Songswave half to the new native child half="yes" works only later than BUILD 7735 (2023-10-23)
geposted Sun 26 Nov 23 @ 12:26 pm
Hi there, is there any chance to get the Jog design from "Project control" to "Controller 2020" ??
geposted Sun 17 Mar 24 @ 12:01 pm
In the latest 'Early Access' VDJ (32-Bit, Build 8055),
the skin has a "bug" now, ie. the Playmarker cannot be 'center-left' anymore.
It only detects the music, if Playmarket is in the middle.
I usually like this Playmarker in the left-left side of the wave,
but it does not display in that location anymore :-\
geposted Fri 29 Mar 24 @ 3:19 pm
Version 3.4.4 - 2024/04/11
change - add a Supporter
change - some Customicons
geposted Thu 11 Apr 24 @ 6:17 am
The beat counter is off again it should be 1 2 3 4
1234 1234 1234 1234
1234 1234 1234 1234
geposted Thu 11 Apr 24 @ 9:48 pm
1234 1234 1234 1234
1234 1234 1234 1234
I know, i have change you wish on the Project Control Skin.
On Controller 2020 I don't make any big changes anymore.
geposted Fri 12 Apr 24 @ 3:39 am
but its wrong and if its wrong it isn't doing its job properly. Its not a wish it should at least be correct. Project Control is wrong also. also.
geposted Sat 13 Apr 24 @ 6:16 am
For the life of me I can't figure out how to add my 3 effects to my decks. Someone help me please!
geposted Sat 13 Apr 24 @ 9:21 pm
Love it! (The skin seems to match up well with use of the DDJ-SR2 controller that I have.) Thanks, man!
geposted Mon 15 Apr 24 @ 4:38 pm
Request
Can it be made that the INFO POIs can be increased
geposted Thu 18 Apr 24 @ 8:49 pm
1234 1234 1234 1234
1234 1234 1234 1234
Youre acting like Im asking for you to add a feature, Im asking for you to correct a wrong. Why not use the default skin for a reference or any other skin for a reference? Why leave it incorrect? Phase means a lot to DJs and this beat counter isn't in phase. All I ask is you follow the examples shown by every other skin
geposted Tue 23 Apr 24 @ 1:32 am
1234 1234 1234 1234
1234 1234 1234 1234
This what you mean is in the "Controller 2020" Skin since Version 3.4.2 - 2023/08/05.
press 4 times "Skin Button"/Top Zone/Beatcounter 1/2/3/4
Look here (sorry OBS don't record the "SKIN-Button" Menu):
geposted Thu 09 May 24 @ 3:53 am
question sir, im using this newest skin of your and ive always have used all your controller skins in the past and with each version ive went in and changed the (time remain) on the jog wheels to match the red and blue of that jog wheel. so ive gotten used to looking around in the XML files BUT im having trouble changing it in this skin. im using the Jog Design 2 but i cant find the line number in the XML to edit the color of the time remain in the jogs ? please help thanks
geposted Sat 18 May 24 @ 3:26 pm
long term user of your skin.....request...are u able to provide a better graphic EQ which enhances bass frequency control?
geposted Mon 27 May 24 @ 9:44 pm
Hi,
First of all, thank you very much for the great work
Because I can't solve a topic.
That the voice always remains stable no matter if the pitch goes to + or -.
Although Keymatch is deactivated.
Hope for your help
Thanks so much
claudio
Hope for your help
Thanks so much
claudio
geposted Thu 29 Aug 24 @ 4:29 pm
