Topic: Crashing by automix - Page: 2
kradcliffe wrote :
Thanks. Did you get any crashlogs on my account?
No, still none logged on your account.
There was one logged for pumpitentertainment which does appear to match the crash that I reproduced here.
geposted Thu 09 Apr 20 @ 8:52 am
That's strange because VDJ did shut down and start again instantly on a couple of the crashes.
geposted Thu 09 Apr 20 @ 8:56 am
I went back and downloaded to an older build 5504 and have ran it all night in automix mode and I have not had any crashes hopefully they can fix this issue I have turned off updates until it gets fixed
geposted Thu 09 Apr 20 @ 1:22 pm
hbsonePRO InfinityMember since 2005
I am haveing the same issue of crashes when using videos and the automix feature. How do I go back to an older build?
geposted Thu 09 Apr 20 @ 5:46 pm
geposted Thu 09 Apr 20 @ 6:24 pm
Thank you, but I need a previous version. I have the one you sent me and that is the one that is crashing. Maybe 5504
geposted Thu 09 Apr 20 @ 6:25 pm
geposted Thu 09 Apr 20 @ 6:28 pm
geposted Thu 09 Apr 20 @ 6:31 pm
geposted Thu 09 Apr 20 @ 6:34 pm
Thanks for the help
geposted Thu 09 Apr 20 @ 6:39 pm
Rune (dj-in-norway) wrote :
That is not links to older builds ;-) thats links to current build
To download earlier builds see here : https://www.virtualdj.com/download/build.html
and choose build number 5504 in the drop-down
(PS - already beta builds with fixes for potential crash in automix, so should update again when next update comes if so, so you are back on latest version then)
http://www.virtualdj.com/download/build.html
https://virtualdj.com/download/virtualdj8/pc64
https://virtualdj.com/download/virtualdj8/pc32
This is how i have it in my saved files folder, but forgot to highlight the upper road...lmao... nevertheless Thanks for the correction.!!!
geposted Thu 09 Apr 20 @ 7:05 pm
djcelPRO InfinityModeratorMember since 2004
Linked to video transition ? Could you select a simple one to test. 32bit or 64bit version on PC ?
geposted Thu 09 Apr 20 @ 10:42 pm
urontvPRO InfinityMember since 2019
Hello:
Good to see others reporting, thought I had a hardware issue.
Current version was also randomly exiting Virtual DJ while using Automix. Will try previous build.
My system. Intel i7-9700KF with 48GB of RAM. Windows 10 Pro v1909. Graphics: NVIDIA Geforce RTX2060
geposted Fri 10 Apr 20 @ 3:00 pm
A new Early Access release is now available that should fix the crash.
If possible, please test and let us know if it is indeed fixed for you.
It looks like it was happening when hardware-accelerated video decoding was used, and it appears to only have happened on nVidia gpu's.
It was not related to video transitions.
geposted Fri 10 Apr 20 @ 5:06 pm
Strange as my GPD pocket has Intel on-board graphics and the Macbook Pro 16" has AMD Radeon Pro.
Tested on both machines and no crashes. Thanks for the fix!
geposted Fri 10 Apr 20 @ 5:33 pm
Ver.5647 seems to have no problem both 32/64bit.
(PC: Intel 9750H/nVidia RTX2060/Win10)
Thanks for the fix!!
However, next song loading waveform is skipping (only happened in automix).
I had no problems until Ver. 5603. I'm glad it will be fixed in the future too.
geposted Fri 10 Apr 20 @ 10:21 pm
