Topic: A#1 best PC laptop to use with Virtual DJ
My computer is about 10 years old now....was top of the top in its day....but not so much anymore....so its time to upgrade. I have a $3k budget...and would like to get the best of the best.
I'm getting a bit older, so large screen is preffered... also I'm a mobile DJ, so having a minimum of 1 TB storage is key....although I could possibly get by with an external drive for requests (don't trust streaming....yet).
So what PC Laptop would the creators of VDJ use? Prefferably a computer that would do stems resolution with as little delay as possible. (LOVE STEMS)
geposted Wed 22 Feb 23 @ 9:41 pm
I have the higher spec version of this one (i9, 32gb, RTX3080ti) and it works great. Decodes stems at 30x so the one below would be a bit slower but still good.
https://www.lenovo.com/us/en/p/laptops/legion-laptops/legion-7-series/legion-7i-gen-7-(16-inch-intel)/len101g0018?orgRef=https%253A%252F%252Fwww.google.com%252F
I just added a 2tb SSD to the spare slot so it now has 3tb in total.
No real issues with latency, nothing that affects the sound anyway. Seems to be an inherent Windows issue that affects some laptops more than others.
With $3k as budget you won't have any trouble to get a good machine.
Go for any gaming laptop you like more and has the specs you want.
Personal suggestions:
1) Avoid Dell Alienware if possible. Some models have issues with DPC latency and you may need to spend a lot of time to troubleshoot it
2) Get a laptop with an RTX 3060 or bigger, with 6GB VRAM or more. With your budget you can most likely get an RTX 3080
3) On most gaming laptops (especially in that price range) adding extra RAM and extra discs common place. So, you can easily get the laptop you like most, and then just add a second M.2 SSD of whatever capacity you want/need
4) Before purchasing, make a quick Google search with the model you're interested at and the words "DPC Latency" next to it. Just to see if any users have any difficult to solve issues first.
Thanks for the help!
What did you go for in the end? I recently spent £3k on a MSI Creator, Intel i9 1490, 64gb RAM, NVIDIA 4070 and in the last 6 weeks it has been having horrendous problems with no rhyme or reason, sounds like it is under water, a reboot of vdj seems to clear it but in the middle of a performance I can't do this! Have had enough!
https://www.overclockers.co.uk/msi-creator-z17-nvidia-rtx-4070-64gb-17-qhd-165hz-intel-i9-14900hx-gaming-lap-msi-01791.html
What sucks more is the price has been dropped :-/
I returned the Lenovo I posted above as the sound kept cutting off with Denon ASIO drivers on my MCX8000 after a couple of hours. Went back to my 6 year old machine and it's fine.
Instead of rebooting you can press "apply" in the audio config and that will reset the audio drivers without leaving VDJ.
Things to try:
Run a DPC latency test to see the general performance of the machine.
Install Windows ultimate power plan and activate it.
Install Parkcontrol and disable core parking.
Adjust the ASIO latency in the control panel (assuming you're using a controller with those drivers)
Howdy!
How about the exact opposite?! I have a $175 with tax budget, lol.
I am currently using a Dell with an AMD A10-7300 Radeon R6 kicking at 1.9ghz. Also 7 GB ram per windows?? Weird
I use my beast PC for making the stems and been using the ancient laptop for live performances. I don't do anything beyond radio level DJ work like weddings and balls so far. So far it seems to work really well, but this laptop just sucks and is slow outside the application.
What would you suggest as a good minimum spec with a little room to grow? I am a video nerd and want to run vids as well at some point.
I'm guessing if I can get by on my old laptop anything is better. I do wonder what extra ram allows.
I owned a music venue outside Phoenix for 10 years up until COVID killed us slowly. I watched for years my friends and artists use virtual DJ. I didn't fully understand what it involved. Recently I switched careers back into the AV world doing events and started doing some small gigs on the side for my boss.
I now get what DJs are doing ! :). I've been super excited to learn how to create some original mixes.
So yea, looking for the absolute cheapest functional laptop I won't go crazy with in a year of dedicated DJ use .
Thank you!
I bought the following computer... worked great at first...but either an update in windows 11 or one of the updates in VDJ has made it where it no longer works with VDJ and the controllers I have... So I'm looking to sell this one (if I can't find a fix) and biting the bullet and just going with an Apple computer... as much as I hate the Apple software setup... I don't have to worry about Microsoft forcing their latest crappy operating system down my throat every 3-5 years.
Do NOT buy this laptop for VDJ....
ASUS GU604VI-M16.I94070
System Model: ROG Zehyrus M16 GU604VI_GU604VI
13th Gen Intel Corei9-13900H 2600MHz, 14 Cores, 20 Logicl Proces
Installed Physical Ram : 16GB
Total Virtal Memory: 16 GB
Page File Space 1.0 GB
NVIDAIA GeForce RTX 4070 GPU
Intel Serial IO UART Host Controller
Intel InnovationPlatform Framework Processor
NTFS 926.35GB Fixed Disk with over 503 GB free
Model: NVMe PC SN560 SDDPNQE-1T00-1002
Intel RST VMD Controller A77F
DjLazerDave wrote :
I don't have to worry about Microsoft...
Apple also release updates that break things. It's been the same for years.
DJ Lyfty wrote :
Howdy!
Thank you!
Used HP Elitebooks are solid built, upgradeable, and have low latency. I'd they come with window 7 even better!
Not wise to suggest people use an unsupported and insecure OS.
Even Windows 10 is EOL in October this year.
Anyone have a PC with Windows 11 that works seemlessly with VDJ and a high end controller like the Dennon Prime 4+.
I've tried 3 laptops now...and all of them have had issues with the the graphics proccessor getting overwhelmed, causing the audio to go to crap.
Starting to think the only solution is to go over to Mac............which I really do not want to do.
You could try skinUseLowPowerGPU to low power to reduce the GPU heat.
Personally no problems with various Dell XPS15/16. (Currently with Intel Core Ultra 9 185H and RTX 4070)
Can you try a full fresh install of Windows 11 from scratch? That worked fine to me (after having loads of issues with GPU spikes, audio pops & cracks, laggy gui, ...).
I agree with @Sepatro - this worked for me on a new Lenovo laptop. No issues for me with a fresh (downloaded from Microsoft) Windows 11 installation.
Apart from the time involved there's no reason not to try.
Many factory Windows builds are riddled with bloatware and unecessary services. Best to start from scratch then add what you actually need.
I recently tried upgrading my 2019 Lenovo C940 to Windows 11 and found it runs cooler and with less CPU use than the factory supplied Windows 10 although it uses more RAM which isn't an issue.
Definitely worth a shot.
wickedmix wrote :
seems like many people are struggling with a clean windows install this can help
just make sure you watch it all and follow the directions closely
https://www.youtube.com/watch?v=0PA1wgdMeeI
This looks great!
