The lyrics are sooo close to replacing karaoke files, but they just need some tweaks.
Dynamic looks cool, but I think most singers would prefer the static mode. The problem is that static mode poorly uses screen space.
Currently, a verse of lyrics looks like " blah blah blah blah blah blah blah", VERY compressed in one single line.
The letter compression really makes it tough to read for a singer.
Is it possible for it to instead use the defined window to make two rows? Ex:
"blah blah blah
Blah blah blah"
"blah blah blah
Blah blah blah"
geposted 5 days ago @ 5:36 am
It also looks like the censor/omit certain words functions aren't working.
I added eight words to censor in the options field and clicked both the "don't show" and "censor audio" fields, then re-analyzed the lyrics, but all the words are still showing up on video and audio.
geposted 5 days ago @ 1:42 pm
Did you separate them with commas? I can confirm it definitely does work.
geposted 5 days ago @ 1:56 pm
Also you don't need/have to reanalyze
geposted 5 days ago @ 2:02 pm
Ok, figured it out. Proper options syntax is: badword, badword2, etc.
Very cool feature devs! Really helps not having to source/edit clean versions!!! Big Thanks
@PhantomDJ. The lyrics don't show (even with show lyrics enabled in options, and on the Video tab) unless I open the lyrics editor and re analyze. Then they show up (even though my options are set to always analyze lyrics). Mac air m4 Sequoia 15.7.2
Is there a way to batch analyze a folder of songs?
geposted 4 days ago @ 8:46 pm
I had an 8 hour gig with the second EA version without any problems.
I used stems. No issues at all (MB Air M2).
Thanks to the VDJ team.
geposted 3 days ago @ 11:25 am
